Increasing Home Efficency - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 01:56 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
Originally Posted by matt151617 View Post
I could see sunlight under the eves in a few spots (soffit vents I'm guessing). There's 2 vents in the attic ceiling also. It was about 65 and sunny here today and the attic was probably about 80.
Make sure that the blown in insulation does not obstruct the soffits.
Old 09-21-2011, 04:58 PM   #17
Registered User
Rewards Points: 5,216
Post a pic of the rim covered by boards. http://www.quadlock.com/technical_li...Insulation.pdf
http://www.professionalroofing.net/a...2/feature2.asp
Gary
Old 09-21-2011, 06:03 PM   #18
Originally Posted by GBR in WA View Post
+1
I remember reading where there was only a 2 degree shift in shingle temperature in Las Vegas for that matter (i.e. extremely hot) between a well vented and completely unvented assembly.
Old 09-21-2011, 06:11 PM   #19
Registered User
Lol, location, location, location. I'm working at a 200 unit apt. complex with 38' trusses from '60's with no intake or exhaust venting, no problems.....
These are of interest, I haven't used them yet; http://www.fsec.ucf.edu/en/publicati...CR-1496-05.pdf
http://www.joelstiburek.com/topten/south.htm
http://www.baileyeng.com/paston_effect.htm
Gary
Old 09-22-2011, 06:08 AM   #20
Gary
Warm up there...?
It is all part of the Sauna/Steam room feature on the building.
Old 09-22-2011, 06:02 PM   #21
Rewards Points: 160
matt151617 is offline   Reply With Quote
Old 09-22-2011, 06:45 PM   #22
Msradell's Avatar
Rewards Points: 126
It would certainly be easy to fill that area with foam and provide good insulation plus prevent air infiltration. Surly a good place to start, that fiberglass isn't doing much good.
Msradell is offline   Reply With Quote
Old 09-22-2011, 06:45 PM   #23
Rewards Points: 160
So just buy about 40 cans of Great Stuff and start filling that area in?
Old 09-22-2011, 06:48 PM   #24
Msradell's Avatar
Rewards Points: 126
You could certainly do that but you probably want to do some looking around for some of the larger kits, they provide better foam you would probably be much cheaper in the long run. Those cans don't go very far!
Old 09-25-2011, 01:52 AM   #25
+1
Buy a larger 2-part kit and get to spraying.
Foam is your friend in this case.
Old 09-25-2011, 03:04 PM   #26
Rewards Points: 160
Any clue where those are sold? All I saw in Lowes and Walmart was a few hundred regular cans of Great Stuff.
Old 09-26-2011, 05:35 AM   #27
Rewards Points: 156
There's a lot of them sold online. I would do a lot of research first.
I think there's one called tiger spray foam and foam it green. Temperature of the foam is extremely important. It's a bit of an expense so you want to do your homework and proceed carefully.
strategery is offline   Reply With Quote
Old 09-26-2011, 10:03 AM   #28
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Find a local building supply house (sells windows, roofing, etc). They should have what's called a "froth pack". Its a small 2-part foam kit, usually in the neighborhood of a few hundred bucks (maybe $400).
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 09-29-2011, 01:56 AM   #29
Rewards Points: 160
Should insulating the rim joists be done all around the whole basement or just the 2 ends where the floor joists end? One end is totally inaccessible due to a bathroom and large storage cabinet. One of the sides would also be difficult to do due to an addition.
Old 09-29-2011, 08:23 AM   #30
Do it where you can access it.
Ideally, the basement is unfinished and you can get to everything but that is often not the case.
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
