Identifying Asbestos Insulation *PIC* - Insulation - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 11:56 AM   #1
Identifying asbestos insulation *PIC*
Most of the gray looking insulation's look the same in pictures so it's really hard to know if my attics have it. I took this picture which shows it as sort of green but in real life it's more gray.
Home was built in 1959.
Labut is offline   Reply With Quote
Old 08-03-2011, 12:02 PM   #2
fabrk8r
fabrk8r's Avatar
That looks like cellulose to me, but I'm not an asbestos expert.
The only way to know for sure if it contains asbestos is to have a sample tested by a lab which specializes in asbestos identification. You can usually find at least one of these labs in larger towns and cities.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-06-2011, 03:52 PM   #3
Rewards Points: 12
fabrk8r is probably right... if it is just the loose batting over the joists in your attic its likely just cellulose. Asbestos was more often used in a spray form (sprayed on concrete) or wrapped around pipes/ducts to insulate them... or in drywall compound... or tile... or... etc....
However, a lab is the only way to be sure if you're really concerned. Be prepared for a whopper of a bill though.
dblade is offline   Reply With Quote
Botched asbestos removal in home... runfrombears General DIY Discussions 28 07-31-2012 09:21 PM
ASBESTOS..... lots of questions. Dyoung Building & Construction 22 02-14-2012 05:15 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
