-   Insulation (http://www.diychatroom.com/f103/)
-   -   I have a "Poor Man's Spray Foam" question (http://www.diychatroom.com/f103/i-have-poor-mans-spray-foam-question-114413/)
Skull Leader 08-17-2011 09:39 PM
I'm looking to do the "Poor Man's Spray Foam" as seen in one of HomeInsulation's youtube videos.
My walls are only 2x4's. I live in one of the coldest places in the US. Last winter we were the coldest place in the US one day at -59. I'm going to be doing this to about 1/3 of my home's exterior walls while renovating a kitchen and living room.
The question I have is can I put both a 2" piece and a 1" piece of Tuff-R on top of each other for an R value of about 19.5? Or will this cause condensation problems or some other problems I'm not forseeing?
Thanks!
AGWhitehouse 08-18-2011 12:43 PM
This is a tough installation to complete effectively and you still have a 1/2" void that allow for convective air currents. You'll also have alot of waste with the custom cuts, which is very costly garbage.
Below is a comparison of two systems...Noting the different R-values, I think you'd be better off in installation time, $, and stress level to fill the bays with unfaced batts. and sheath the wall with 1/2" foil-faced polyiso before you sheetrock. The foil-face with taped seams and penetrations will give you the air and vapor barrier needed while greatly reducing the thermal bridging that the studs create.
A whole different approach is to sheath the exterior of your house with nail-base foam panels. This would require re-siding, so I'm not sure if this is even in your deck of cards.
OOPS...done quick and without great review, the titles of the charts are backwards. The cut foam scenario is on the right...
bowlofkibble 07-14-2015 09:47 PM
Is this technique agreeable? I know this is an old post but I've been considering this idea, the one in the original post and plenty of others for insulating.
GeselleBrian 07-15-2015 02:29 AM
can you not just stuff the wall with Fiberglass or Rockwool?
bowlofkibble 07-16-2015 08:07 PM
Of course that is an option, but air sealing seems to be kind of a big deal it seems and using these techniques makes the idea of air sealing much easier to fulfill. There is a video titled "Attic Insulation Done Wrong… and How to Do It Right!" (unable to post links) that might help illustrate this idea a bit.
Hick 07-16-2015 08:15 PM
Air seal with expando foam, THEN put batts of insulation in The way whitehouse suggested with unfaced & foil ontop might give you better insulation.
However, faced batts of insulation will give you plenty of insulation for likely a much cheaper price. If we are going the "poor mans" route, that would likely be the cheapest & work just fine.
I understand fully about insulation. Hell my walls have outer sheath, 3/4" foil board, tar paper, inner sheath, R-13 insulation, sheetrock & cedar slats.. Dunno the exact R value but I am sure it is high. Overkill but...I stay cool in summer & warm in winter. I tried the poor mans insulation route for under my floor but was more trouble than it was worth.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
