Hybrid Insulation For Solid-wood Walls - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 08:42 AM   #16
WoW, I already read through a lot of Building Science website. Amazing stuff! But I had a hard time finding info on solid-wood walls. And a lot of their stuff is pro-sprayed foam, for obvious reasons, but a path I would still like to avoid... I'll check the links a little later.
Thank you both for your input and clarification. Much appreciated. I may actually mix techniques... Use all rigid for a stairwell and bathroom for example (where I'm tighter for room and there are no plugs) and hybrid for the rest.
Thanks again!
manbitesfilm is offline   Reply With Quote
Insulation Behind New Bathroom Walls mothersong Building & Construction 8 07-11-2011 09:41 AM
Exterior walls need upgrade in insulation xjsparky Insulation 7 06-22-2011 09:43 PM
adding insulation exterior walls, is it worth it? justin76 Insulation 9 03-07-2011 09:57 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
