HUSKY SHEETING From HD - Insulation - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 04:30 PM   #1
HUSKY SHEETING from HD
I am trying to find some ployethylene sheeting for vapor barrier in the crawl space. Home Depot seems to have it -
http://www.homedepot.com/webapp/wcs/...de=cii_9324560
but no where on the box does it say ployethylene. I am hesitant to buy it without a clear indication that it is poly and not a non-poly plastic. The verbage on HD's site is often inaccurate so I dont trust what the online labeling says.
Thanks,
Kevin
kevsprojects is offline   Reply With Quote
Old 03-11-2012, 04:36 PM   #2
Rewards Points: 13,450
That's the one to use.
Pick up some 16" insulation hangers to be bent in half to hold it in place.
Roll it out in the yard and measure and precut it before you go under the house. Roll it up, slide it in the hole. Tack it in place againt an end wall turn around and unroll it crawling on top of the plactic but do not add anymore stakes until you get to the end. Pull it tight and get it streight, tack it and work your way back tacking as you go. Make sure to add some where the vents are so the wind does blow it up. Also add extra where the crawl space door is so as someone crawls in there not messing it up.
Old 03-11-2012, 06:23 PM   #3
bbo
fyi, everywhereI look on the web it lists it as polyethelene.
feel free to contact the manufacturer yourself for confidence.
http://www.poly-america.com/ContactUs.html
bbo is offline   Reply With Quote
Old 03-11-2012, 09:55 PM   #4
Thanks for the contact link bbo. I think it is poly but it would be helpful if they would just say it on the box. I'll give em a ring in the morning. I just want to hear em say "its poly" before I turn loose of the loot.
Old 03-12-2012, 11:29 AM   #5
Yep! it's poly. I call em and they verified it. Just had to hear it direct.
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-17-2012 11:57 PM
Moisture Under Attic Storage Sheeting cdcrawford25 Insulation 8 01-08-2012 06:13 PM
NEED URGENT ADVICE: roof sheeting question diybrad Roofing/Siding 2 11-15-2011 01:02 PM
What size plastic sheeting to use? Joe D Painting 2 01-11-2011 11:03 AM
Stripping a roof with Skip Sheeting atmironov Roofing/Siding 32 10-14-2010 03:08 PM
