Huge Problem With Insulation In Cape Style - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 10:04 PM   #31
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,168
Not unless you are allow for the incoming ambient temperature air from somewhere else. If not, all you will be doing is just pulling more heat from the home.
If you don't want to spray foam the roof deck and covert the attic to a sealed attic, you need to open up the soffits as I stated earlier in the thread.
You can open the soffits back up (remove the foam and/or re-do the soffits) and allow the ambient outside air to vent into the kneewall area and back up the roof where the kneewall meets the roof deck (it will also have to be re-opened).
Air sealing and insulating the attic floor is a definite must as well. That will help mitigate the heat loss via bulk air movement and radiant loss of heat.
Tags
insulation , roofing , ventalation
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Color options for a small cape style home Staticman2 General DIY Discussions 2 06-20-2009 12:53 PM
