How Would You Repair This Exterior Foundation Insulation/wrap? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 12:09 AM   #1
Question
How would you repair this exterior foundation insulation/wrap?
Usually I don't get stumped like this, but I'm finally at such a loss my brain hurts.
A home I purchased, which was built in 2005 located in the upper Minnesota/US (frigid winters, balmy summers) has the larger faces of the above-grade poured foundation covered in a strange insulation on the outside I cannot ascertain to the life of me what it is, where to get more of it; or how to fix it.
As you can see below, various parts are 'ripped'; I'm guessing partly due to a poor trimming job and also due to shrinkage from hot summer sun.
I've had advice to "rip it all off, insulation doesn't belong outside"; but I do know people use foam panels on the outside (WHY it's this fiberglass stuff is beyond me...) Pulling it off isn't really an option unless I cover it back up because the foundation is sealed with the black foundation sealant (roll-on tar -like stuff) and the fiberglass strands are half stuck to it.
thinice is offline   Reply With Quote
Old 06-28-2014, 09:09 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,020
Doesn't look like it is going to hold up much longer so you might as well get used to the idea of re-doing it.
It isn't proper application to be certain.
What is the foundation wall? Poured, block, etc., ?
Old 06-28-2014, 03:18 PM   #3
Poured
Poured;
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
