How Would You Insulate THIS? - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 10:44 AM   #31
GBrackins's Avatar
Rewards Points: 2,106
one other potential issue I just noticed in your photo regards the stairs. It appears your riser height may exceed the code requirement as your stairs appear steep. This may be caused by the angle of the photo. It may be that VT has modified the IRC code to allow something different. In Massachusetts our riser height maximum is 8-1/4" and our minimum tread depth is 9". I would suggest finding out what your requirements are.
per the 2009 International Residential Code
R311.7.4.1 Riser height. The maximum riser height shall be 73/4 inches (196 mm). The riser shall be measured vertically between leading edges of the adjacent treads. The greatest riser height within any flight of stairs shall not exceed the smallest by more than 3/8 inch (9.5 mm).
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
How to Vent and Insulate an Enclosed Porch Converted to an Entry Room psubaron Roofing/Siding 14 09-13-2012 08:35 AM
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
To insulate or not to insulate? brokenhammer Building & Construction 2 11-24-2010 06:10 AM
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 11:13 AM
How to Insulate behind Wall Stack Supply Duct whirly HVAC 5 03-08-2010 04:47 PM
