How To Stop Air Infiltration In Large Hole Under Tub - Insulation - DIY Chatroom Home Improvement Forum
Old 02-17-2014, 04:37 PM   #1
How to stop air infiltration in large hole under tub
I have a 63 year old house that a lot of people have apparently worked on in the past. Under the tub in one bathroom there is a very large hole (2' x 2', a little irregular) that is allowing cold air from the crawlspace to cool the tub and go up between the studs, cooling the room by as much as 20F in the winter. I was going to cut and glue/screw rigid foam board to stop the air from entering, but due to how many pipes are there I couldn't get even two or three smaller pieces of rigid foam board maneuvered into place.
What is the best way to stop the air from entering? I have some R30 unfaced fiberglass insulation I was considering just stuffing densely up in the hole, but I've read fiberglass insulation isn't really an air barrier. I'm unaware of any spray foam product that would work since the void is so large. The water heater is directly above, so there is a very hot pipe exiting the water heater in this void I have to deal with as well.
giddyup05 is offline   Reply With Quote
Old 02-17-2014, 05:38 PM   #2
Rewards Points: 13,960
Post a picture, we all know what your talking about, just have no way of seeing it from here to make a good suggestion.
Old 02-17-2014, 06:18 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,224
Picture will help.
Probably plywood that is air sealed up is your best bet.
Probably worth considering the conditioning of the crawl as a general rule in addition to what you are looking at here.
Old 02-17-2014, 06:25 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 788
Without seeing it, I'd put batt insulation up in the hole to fill the voids. Then try to piece the rigid in the best you can.
you can also find insulation wrapped in vinyl- like is used in pole barns. This can be hung from the joists- under the p trap and water lines
Old 02-18-2014, 05:47 PM   #5
Registered User
Rewards Points: 526
You could use some FG in a garbage bag, pull small pieces from batt- then fire-stopping.. It really requires a fire stop, per code; http://publicecodes.cyberregs.com/ic...002_par017.htm
Remember FG/rock wool are air permeable, letting moisture to the wood framing; http://publicecodes.cyberregs.com/ic...002_par018.htm
Gary
Old 02-18-2014, 06:52 PM   #6
MarginallyQualified
Rewards Points: 2,464
Originally Posted by giddyup05 View Post
...there is a very large hole ... allowing cold air from the crawlspace
You should probably close that up.
Old 03-04-2014, 10:28 AM   #7
Rewards Points: 186
I second the Fiber Glass batts in plastic bags to get your major holes filled, then try and put some rigid on top if possible. But I'm in the same boat, looking up into the tub from the unfinished basement there are huge holes, and I've sealed a good deal of stud bays with fiberglass batts (no paper backing) in regular grocery bags. The plastic makes the air seal (sort of), but if you get enough fiberglass in bags into the space you could seal with polyethylene underneath to get a good air seal.
Basically stick as much fiberglass up in there in bags and then polyethylene seal at the bottom would by my advice. But it's hard to say without pictures.
Ocelaris is offline   Reply With Quote
Old 03-04-2014, 10:27 PM   #8
Registered User
Rewards Points: 526
Oc, over a crawlspace, IMO a poly sheet would be a bad idea as would poly shopping bags because they are vapor barriers (maybe in Canada and only with full stud cavity fill and full-contact with the drywall). Because the OP has to add plywood for the fire-stop (hole in the decking), poly would be a mute point, don't you agree.... FB is good though.
Gary
Old 03-05-2014, 05:07 PM   #9
Rewards Points: 1,476
I would do a combination of rigid foam and spray foam.
mikegp is offline   Reply With Quote
Old 03-05-2014, 06:03 PM   #10
Rewards Points: 186
Maybe I was misunderstanding his original post, but I thought I took away from it that he couldn't even figure out how to attach multiple small pieces of rigid foam. From that I assumed he could not do even plywood, which is why I suggested bags filled with fiberglass. You are right about not doing polyethylene sheeting under fiberglass batts, my bad. It appears that if you want to do a vapor barrier it has to be on the hot side in this case.
http://inspectapedia.com/Energy/Base...r_Location.htm
Old 03-05-2014, 08:19 PM   #11
Registered User
Rewards Points: 526
The bags would work to insulate the area around the tub (as I said in Post 5 earlier), but the flooring requires a solid structure repair. With a 2x2 hole you allow fire/moisture/air through. I have screwed plywood under the bags after using low-exp. canned foam to keep the tub water warm longer. Foam board may also require a covering against fire other than fiberglass insulation or drywall (not in a crawl...). Check with local AHJ when using alternative measures other than prescriptive codes.
Gary
Approaching a repair to a large plaster hole bobward23 Drywall & Plaster 2 07-26-2012 09:51 AM
Large tree branch made hole in shed roof ohioweaver Roofing/Siding 9 04-19-2011 09:48 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
