How To Sheathe A Wall Under Eaves? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 05:13 PM   #1
Rewards Points: 33
How To Sheathe a Wall Under Eaves?
How should this upper section of the exterior wall be sheated in preparation for a thick bed of insulation in the side attics around a finished attic room?
Name:  Exposed Interior Under Eaves.jpg
I am in climate zone 5A (SW Michigan)
Lascaux is offline   Reply With Quote
Old 06-08-2012, 04:08 PM   #2
Rewards Points: 33
Wall Assembly To Be Sheathed and Insulated in Climate Zone 5A
Here is a drawing of the wall assembly:
I think that I need to sheathe above the brick and up to the top of the joists before I install insulation in the side attic floor. How do I best do this in climate zone 5A?
Old 06-10-2012, 08:46 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,842
Those joist bays need to have rigid blockers installed in them and them foam sealed from the sides and top. Make sure there is a proper vent space to allow the soffit air to draft up along the roof line and into the attic.
Old 06-11-2012, 06:39 PM   #4
Rewards Points: 33
Thanks, WoW. I plan to block the joist bays with Foamular 250 both at this outside wall and at the point where the joists go under the finished attic room:
I am considering sheathing the upper part of this outer wall with a continuous air barrier of sealed Owens Corning Foamular 250. This sheathe would start just above the level of the brick cladding. I would retain the vertical gap between the brick cladding and the fiberboard so that the original construction of the first floor below would not be altered. I would allow air to continue to enter here.
The sheathing above the first floor would provide a barrier up to the (Provent) rafter vents. I would insulate up to to above the joists and then block both between the joists and up to the rafter vents on the inside of the wall. Is this overkill?
Also, In order to create an acoustic barrier between the finished attic room and the family room below, can I fill the joist bays below? There is electrical running through the bays. It's rubber, 2-conductor cables into j-boxes. It is unlikely that I will be able to replace the wiring below this floor.
Old 06-14-2012, 02:14 PM   #5
Rewards Points: 33
1.5 Story Under-Eaves Wall Sheathing
I'm working on answering my own question...
"The Guide to Attic Air Sealing" on buildingscience.com has some pertinent information in the section on a Two Story Wall (pg 34-35).
Tags
attic , eaves , insulation , sheating , soffit
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 07:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
