Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 03-17-2011, 12:28 PM   #1
How many bags of blown-in cellulose insulation do I need
I have 2000 square feet of attic with a with an R value of 25-- How many bags of cellulose do I need to bring it up to an R-value of 49 or 60???
rschmiss is offline   Reply With Quote
Old 03-17-2011, 12:30 PM   #2
Experienced
Jackofall1's Avatar
Hi and welcome rschmiss, to the best darn DIY'r site on the web.
Edit - Here is a guide to your answer - http://www.ehow.com/how_5896930_calc...age-attic.html
Lowes also has a calculator for the same purpose
Mark
Old 03-17-2011, 02:25 PM   #3
There is no generic coverage chart for cellulose insulation -- or any other loose fill insulation for that matter. You will have to consult the coverage chart for the specific product you intend to install. On the chart you will find rows for R13, 19, 22, 30, 38 and 49. Some manufacturers provide additional R-value information. None of these rows will give you exactly R49 assuming an existing R25, but you can make a reasonable estimate. If your existing insulation is loose fill fiber glass there will be some compression if you put cellulose on top of it. In that case you may want to arbitrarily choose to install an additional R-30. The final insulation deck will cedrtainly be somewhere between R50 and R55.
dleaoh is offline   Reply With Quote
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 11:16 PM
Cellulose blown in insulation questions... 1eagertolearn Remodeling 3 10-02-2010 12:42 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
Insulation - Cellulose vs. Icynene meth Building & Construction 24 04-29-2009 10:12 AM
Cellulose insulation as mulch gmatov General Discussion 7 06-23-2008 07:45 PM
