How To Make Woodplugs For Blowing Insulation - & Blower Rental - Insulation - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 11:26 PM   #1
Question
How to make woodplugs for blowing insulation - & Blower rental
Appreciate any help the group can lend.
- I would like to know specifics about the plugs used when blowing insulation into walls from the outside. Are the plugs the same size as the hole, if so how do you secure it from falling in? Are they made out of plywood? how think should they be? Do they have a cone shape?
- Understand the blowers used for attics are not powerful enough for tight packing needed for walls (2.9psi). Is it easy to rent the types of blowers required?
Thanks for responding,
K
ksmall is offline   Reply With Quote
Tags
blow , blowers , insulation , plugs , wall
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
2x4 Exterior Wall Insulation stubits Building & Construction 4 03-19-2009 07:03 AM
