How To Insulate Rim Joists Simply - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 08:30 PM   #31
concretemasonry's Avatar
Rewards Points: 2,608
It sounds like a good plan that I have used several times on homes if owned over the last 30 years. You will get some criticism from code reference citers and hair splitters that deal on .001's on perm ratings. It is just a small space, so do not worry about much because what you propose is estimated at a 98.7768365% improvement for a small area relatively.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Gary in WA (02-02-2014)
Old 02-02-2014, 08:53 PM   #32
Registered User
Rewards Points: 5,514
Lol.
Cj, if you air sealed the rim joist (with a sealant) from the mud-sill plate and deck sheeting above before adding the foam board, you will be fine. The rim will expand/contract over the seasons allowing infiltrating air, sometimes moist; http://www.buildingscience.com/docum...d-but-strange/
Page 51; http://books.google.com/books?id=iwS...joists&f=false
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
chronojosh (02-02-2014)
Move joists for higher ceiling jgrohol Building & Construction 11 10-03-2012 04:24 PM
Best way to frame in a lateral bracing between joists miamicuse Building & Construction 2 03-19-2012 10:08 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 07:28 PM
Cut Joists - How to Repair? stubits Building & Construction 13 03-16-2010 05:12 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
