How To Insulate Metal Roofing From The Interior - Insulation - DIY Chatroom Home Improvement Forum
Old 01-28-2014, 03:33 PM   #1
How to Insulate Metal Roofing from the Interior
The drawings call for R30 rigid insulation. I was hoping to find a CAD detail...............metal clips maybe glued to the underside of the metal roofing?
PappyO is offline   Reply With Quote
Old 01-28-2014, 09:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
What type of roof/attic structure?
You are talking about quite an undertaking and a layer of rigid foam with SPF would by my recommendation.
Old 01-29-2014, 01:46 PM   #3
It's a metal building structure (beams, girders, joists, spandrels, purlins) it has fire damage and they want R30 insulation installed (it calls for ridgit foam on the DWG) but I guess what ever is the most cost effective will work.
Old 01-29-2014, 02:54 PM   #4
Can you post up a picture? Most steel buildings are most effectively and easily insulated with Spray Foam.
Old 02-09-2014, 10:54 PM   #5
Rewards Points: 1,092
Pappy: I am not a pro, but I would not consider anything but spray foam on a metal roof. Trying to adhere rigid foam, in layers, is going to be an enormous PITA, and I don't think it will end up being airtight. There is a max thickness that can be sprayed at once, so inquire about that with the spray company.
The Following User Says Thank You to jklingel For This Useful Post:
Windows on Wash (02-10-2014)
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
metal roofing jhack836 Roofing/Siding 4 07-02-2012 12:17 AM
Best way to seal new Chimney through Metal Roofing tuchodi Roofing/Siding 5 03-01-2010 10:45 AM
Large metal "tabs" in openings cut in bi-level rim joist... What are they? Insulate? nutlog Building & Construction 9 11-09-2009 04:19 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
