#1 |
how to install roxul insulation in a crawl space ciling.
I have already encapsulated the crawl space with a 12 mill vapor barrier and also used spray foam in the wall cavities.
but the house wood floors is still feel cold. We removed the old fiber glass insulation and have not installed anything else yet. I'd like to put roxul R23, which is 5 1/2" thick. I live in Maryland and I like to know if I need a vapor barrier in between the floor joists before installing roxul. Is this a good way to go. Thank you. Last edited by plastic; 12-10-2011 at 11:06 AM. Reason: miss spelling a word |
#2 | |
how to install roxul insulation in a crawl space ciling.Quote:
Few other things to check since the floors still feel cold that I am in the process of doing in my home. Check the rim joists, mine were lightly stuffed with smashed up fiberglass. I can't tell you how much air they were letting in. I just sealed with a good sealant and cut to fit foam board (XPS) sealed in place with great stuff foam. Also seal the sill ledge, I had a quarter inch gap in some spots I checked where I can see outside. As you can imagine the air was just gushing in. Also seal up some holes for cable lines, electric, etc... if you have any running down there. |
#3 |
Exterior Construction
If you don't have a high water table in that area, insulate the crawlspace wall and supply some conditioned air to the crawlspace via a supply side duct.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Thank you for responding to my post.
My crawl space is as a mention 24'x31' and is around 3 1/2' in height. I started by removing the old fiber glass insulation on the crawl space ceiling and then replace the 6 mill vapor barrier with a 12 mill from crwal space concept, it is great stuff. I would recomend this to anybody. The crawl space used to be vented, not anymore, I seal all vents with foam board from the inside and put spray foam around the edge to seal it completely. Then I used foam it green spray foam insulation on the joists cavities, but I was only able to spray 1" thick because this stuff it is expensive. My wife did not want me to put fiber glass insulation back in tha crawl space because she thinks that if I do, mice will come back. Therefore I started doing research and came acrross Roxul insulation, and I think that once I put this in the crawl space ceiling, the hose floor should feel a little bit warmer. I will be using R23 roxul, which is about 5 1/2" thick, I call roxul in canada and they told me that I do not need a vapor barrier as long as long as the crawl space has been encapsulated. I hope that this helps someone. Thank you for your input. |
| The Following User Says Thank You to plastic For This Useful Post: | cbaur88 (12-13-2011) |
#5 | |
#6 |
Moderator
Plastic, welcome to the forum!
Sounds like I'm a bit late here.... for others reading; As WW said above- http://publicecodes.citation.com/ico...008_par002.htm http://www.buildingscience.com/docum...n-crawlspaces/ http://www.buildingscience.com/docum...ance-and-codes Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Bad smell in crawl space. | John_W | General Discussion | 30 | 06-07-2013 02:57 PM |
| Crawl Space Insulation - Will this work? | pjh3939 | Insulation | 4 | 12-03-2011 10:36 AM |
| Help with complicated insulation project in attic | OhmZoned | Insulation | 12 | 11-19-2011 09:49 AM |
| Crawl Space Insulation | jim smith | General Discussion | 3 | 11-17-2011 06:14 PM |
| Unvented crawl space insulation | ehardman | Building & Construction | 3 | 01-13-2009 01:44 PM |
