How To Install Roxul In Crawlspace - Insulation - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 11:48 AM   #1
How to install Roxul in crawlspace
I would like to install Roxul(stone wool) insulation under subfloor. I am located in NY, Long Island. Roxul will be installed in a vented crawlspace. Since Roxul is not kraft-paper-faced like fiberglass, do I have to install vapor barrier between batts and subfloor? If I do, then what kind: plastic(mil?), tar paper else? Thanks!
CatAthena1 is offline   Reply With Quote
Old 05-09-2013, 03:55 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
a simple call to your building official will answer that question, after all they are familiar with your local code requirements.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-11-2013, 10:06 PM   #3
Registered User
Rewards Points: 5,516
True, good advice! See if they accept the sub-floor sheathing as a vapor retarder and if able to cover it with a housewrap to stop air from wind-washing and degrading the R-value.
Gary
Tags
insulation , roxul , subfloor under framing , vented crawlspace
getting the most out of a heated crawlspace Gerry Fossum HVAC 2 06-08-2011 07:42 PM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
Crawlspace Ventilation kagelsr1 Building & Construction 9 02-18-2011 08:11 AM
conditioned crawlspace fan albertpinto HVAC 4 12-27-2010 04:46 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
