How Do I Deal With This Small Space ? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 08:47 PM   #1
Rewards Points: 236
how do i deal with this small space ?
see pic. i have 1" xps going against the sheathing . and i am putting in 1" spacer on the stud, so i can still use 3 1/2" insulation. but in this spot , there is about 1 1/2" gap. removing that board is not a good idea for a few reasons. i am thinking to just get some fiberglas in there as best as possible, and call it a day. what do you think ?
Fix'n it is offline   Reply With Quote
Old 07-29-2012, 08:59 PM   #2
Rewards Points: 1,092
you can pull the fg batts in half to thin them. if it's just one spot, it hardly matters if you stuff it in or split it. if this is a large area, well beyond the picture, it may be wise to get better insulation that fg batts; it is the worst there is. are you air sealing? that is the big issue.
Old 07-29-2012, 09:07 PM   #3
Rewards Points: 236
i have 3 of those bays in this room, 4 total for 2 rooms on that side of the house. the one you see is where the closet door is in the room.
yes, i am air sealing. then, if things go well. i am going to put xps on the exterior under new siding.
Old 07-29-2012, 09:17 PM   #4
sounds like you have things under control. there is a good article on greenbuildingadvisor.com (blog, i think) on how much exterior foam is adequate to keep the sheathing from getting cold, condensing, and rotting. in your area, 2" is probably enough, but i'd read the article and not rely on my memory. tape and air seal the foam, too. good luck.
The Following User Says Thank You to jklingel For This Useful Post:
Fix'n it (07-29-2012)
Ideas for landscaping small space mscottonblossom Landscaping & Lawn Care 0 02-28-2011 05:43 PM
Crawl Space Advice mjarema414 Building & Construction 0 02-04-2011 08:09 AM
Low ceiling and small space eadams783 Roofing/Siding 2 01-01-2011 07:48 AM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Can I run a small (500 watt) 240 V space heater at 120V? pcampbell Electrical 6 01-08-2009 09:56 PM
