How To Detail Outlets On Thick Rigid Foam Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 06:03 AM   #1
how to detail outlets on thick rigid foam walls
While I think this question might be under the topic of electrical I have a feeling that people in this group have dealt with this issue before.
I am working on a project that will re-skin my house. In the end the exterior walls will be 2 3/4" thick from the outside of the stud to the outside of the siding (1/2" plywood, Tyvek, 1"XPS, 3/4" Rainscreen, 1/2" Siding) I plan on using Quickflash (http://www.quickflashproducts.com/pr...lectrical.html) for all wall penetrations, to tie into the tyvek. But I'm having a hard time visualizing how the details work on the outlet and 3/0 electrical boxes.
So for example the max depth on the E-SGB-C is 1 3/8". The quick flashing goes at the tyvek layer, that still leaves 2 1/4" (2 3/4 - 1/2 plywood) to the outside of the siding. That means i'm left with a 1 1/8" gap. how do I deal with that?
Most of the outdoor covers I've seen only have a small lip on the back.
Any thoughts or input would be great! pic would be even better.
thanks
mmoses101-1 is offline   Reply With Quote
Old 08-03-2013, 07:48 AM   #2
Rewards Points: 14,306
I hope that's not the order you plan on covering that outside wall.
I can see that being a double vapor and having moisture trapped inside the walls.
Have you checked to see how much wiring is available inside the outlet boxes.
Need enough so there's no hidden junctions in behind the wall.
Do you plan on pulling all the windows and doors and resetting them to that new wall thickness?
Old 08-03-2013, 10:10 AM   #3
Not to sideline the question, which is about detailing outlets not wall assembly...but yes that is order and no there is no double vapor barrier. Tyvek is vapor permeable.
http://www2.dupont.com/Tyvek_Weather...ads/K01472.pdf
The wall enclosure follows a well understand Building Science design.
http://www.buildingscience.com/docum...e-perfect-wall
Tags
outlets , xps
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 10:07 PM
Foam vs. Cellulose insulation in walls nhoj Insulation 10 12-19-2012 06:56 AM
Fireblocking top of rigid foam board? ndmeier Insulation 1 02-01-2012 08:27 PM
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 03:07 AM
Best Foam for Basement Walls? heybrady Remodeling 5 08-19-2008 10:31 AM
