How To Cut And Seal Insulation - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 07:42 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Use a foam compatible sealant. PL might melt the foam.
Old 12-06-2012, 10:03 AM   #17
Rewards Points: 150
Actually pl300 is made specifically for adhering to xps just need to know if it will give me the proper seal at the seams and the concrete floor as well.
Mijotter is offline   Reply With Quote
Old 12-06-2012, 12:32 PM   #18
Just make sure the concrete is clean and it should work.
Old 12-07-2012, 10:23 PM   #19
Screws and Nails! If the glue doesn't work.
rebelranger is offline   Reply With Quote
Old 12-10-2012, 01:23 PM   #20
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
Hey don't rule the table saw idea out just yet, if you havent already completed this project. Depending on whether you have enough outfeed and side feed support around your saw, and its rip capacity, we use 2"xps all the time at work and unless it's a random small peice or doesnt break on one of the joints we used the table saw for any repetitive cuts. Nice clean edge for tight fit. It does make a pink mess.Im just speaking from personal experience, not sure if its right or wrong but it does yield good results. Good luck with your project
jpc is offline   Reply With Quote
Old 12-10-2012, 02:46 PM   #21
Registered User
Rewards Points: 5,516
Check with your local AHJ as the f.b. may require positive fastening per Code.The adhesive pattern is important, no air to concrete; http://joneakes.com/jons-fixit-database/743
Use the waste on the rims; http://www.buildingscience.com/docum...l_seal_rev.pdf
Use canned foam under them and between joints or mastic/tape because it may shrink later; http://www.buildingscience.com/docum...a-foam-shrinks
Gary
Old 12-10-2012, 06:54 PM   #22
Rewards Points: 150
Ok so everywhere I look people are suggesting this Great Stuff...stuff. However I cannot find any information if it's compatible with xps rigid foam foam or not. And is this Great Stuff truly safe as far as vapors and coming in contact with moisture/condensation goes? If there a caulk or sealant alternative out there? Please help and thank you.
Tags
cut , insulation , joist , score , xps
