Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 02-19-2013, 07:18 PM   #1
How to correctly insulate this
Hey everyone,
Finally have gutted the rooms I am remodeling and am looking at materials for the transition between the room and the wall. As always a picture is worth a 1000 words.
The white is the foam vent on the underside of the roof sheathing, black is rock wool insulation (which will be coming out of the wall).
The attic has an R40 value of blow in in it, but the entire perimeter of this room (over 30ft of exterior wall) has no insulation other than the rock wool for the last 1-1.5 feet of the ceiling joists.
I have very little space to work with, the roof has a very low pitch and is a hip roof, which makes the outside corner even worse.
I understand the need to make sure I have air flow to keep the attic cold.
One possible option I have thought of is to use 2 inch XPS to create what would be similar to those foam vents, seal the XPS to the header, then fill the space between the foam and the Vapor barrier with the blown in material, then add more material to make up for the lost amount over the center of the house.
Other ideas?
Appreciate the commentary!
quackaddict is offline   Reply With Quote
How to Vent and Insulate an Enclosed Porch Converted to an Entry Room psubaron Roofing/Siding 14 09-13-2012 09:35 AM
How to correctly insulate with bats demandrew Insulation 2 02-28-2012 08:09 AM
Insulate basement header with imbedded joists??? lackofunds General Discussion 21 04-17-2011 04:41 PM
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 12:13 PM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 07:07 PM
