How Can You Walk In An Attic With Thick Blown-in Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 02:52 AM   #1
How can you walk in an attic with thick blown-in insulation
My contractor is going to put R38 blown-in cellulose insulation in my ranch house (gable roof) attic. He said it will cover everything including the joist.
Then how can you walkto anywhere? It seems it's very easy to step on to the ceiling and create serious damages.
The reason I ask is that after the insulation work, I have couple of projects to do: 2 bathrooms remodeling, 30 recess lights, both of which requires going into the attic.
htabbas is offline   Reply With Quote
Old 11-09-2011, 06:07 AM   #2
DIY staff
Rewards Points: 7,174
You be very careful----I know that sounds like a smart answers --but that what everybody must do.
If you use remodeling cans the majority of the wiring can be done from below.
Dropping the ceiling out of the bath will save you from having to wade through the snow until the very end of the job when you return only to reinstall the insulation in that section.
Old 11-10-2011, 09:43 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,024
Carefully.
If you can get it done first, knock it out now. This way you can seal around the penetrations for proper air seal as well.
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Damp Insulation in Attic wiz561 Building & Construction 6 12-24-2010 12:16 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Attic Insulation Installation oktooma Building & Construction 3 10-29-2008 04:46 AM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 08:10 AM
