House Under Construction ... With Moisture Problems !!! - Insulation - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 09:08 PM   #1
House Under Construction ... with moisture problems !!!
Ok... here it go`s
I live in cold Canada and i had issues with my building permit so i couldnt insulate the house before winter arrived....
Since January I have been heating the house to get all condensation that turned into frost while I couldnt heat...
now the house is all dry I went and put R-20 Insulation batt .. next morning i get to the house I check under the insulation and there it was.... MOISTURE....
what should i do .... or what Am I missing ????
ken338 is offline   Reply With Quote
Old 03-10-2012, 09:31 PM   #2
Rewards Points: 13,712
Sounds like the walls are still satuated with moisture.
Pull all the insulation back down and run at least one dehumidifier until the air has about 40 % humidy.
Old 03-10-2012, 09:43 PM   #3
i went this morning walls looks dry but only were the bottom plate of the wall looks a little moist.... after its dry i should insulate then vapor barrier and seal ?
I have 8 fans running the air movements and only one dehumidifier... and can only get it down 48%
???? what a pain
Old 03-10-2012, 10:08 PM   #4
Rewards Points: 1,092
Suspicion: You are insulating and not air sealing, so the exterior sheathing is getting cold. Air carrying moisture gets out to the wall and condenses. You need to air seal immediately after you insulate, and use the vapor barrier if you have to. Better would be super-good air sealing, but you may have a code mandating a poly vapor barrier in Canada. If you get a tad of moisture on the exterior wall and the wall is vapor open, it should dry come spring. That is another reason why vapor barriers are being avoided as much as possible; they prevent a wall from drying inward as well.
The Following User Says Thank You to jklingel For This Useful Post:
Tom Struble (03-11-2012)
Old 03-11-2012, 02:21 PM   #5
could having the outside with the typar and Canexel siding on change something of the situation... and for the inside vapor barrier here in Canada we can use poly vapor barrier.... and seal top, sides and bottom with acoustic sealant....
Old 03-11-2012, 04:45 PM   #6
Rewards Points: 512
i'd be putting 1-2more dehu's in there, whats the moisture content of the bottom plate? anything under 13% and i'd start insulating and the RH should be below 48. just give it a couple days
princelake is offline   Reply With Quote
Old 03-11-2012, 06:21 PM   #7
thats what i am asking myself too... but as soon as I point the fans on the plate for a day or so its dry....
the heat in the house is from 20 C ( 68 F ) to 23 C ( 73 F )... as I check about an hour ago the dehumidifier it shown 50% on it... might not be accurate... but last week it was showing 70%
Old 03-11-2012, 06:29 PM   #8
Rewards Points: 252
Since you are heating the house you need a vapour barrier to stop the moisture in the hot air from travelling through the fiberglass and condensing on the cold exterior sheathing. Your typar and wood siding are vapour permable, so you won't be trapping the moisture in the wall by installing the interior vapour barrier.
shazapple is offline   Reply With Quote
Old 03-11-2012, 08:52 PM   #9
Rewards Points: 512
sounds like your getting really really close to the proper numbers you need to safely start insulating without having moisture/mold problems. maybe buy a cheap prober for checking the moisture content and if its low enough start putting the insulation in again.
New House, new problems. need Wall Answers MerrittHII Building & Construction 0 03-06-2011 08:55 PM
house condensation? electrical problems? treerat Electrical 4 02-28-2011 05:23 PM
Winter house construction bronco2 Building & Construction 7 12-12-2009 10:39 PM
Moisture in Bathroom and whole House dankreboot Plumbing 2 09-22-2008 05:22 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 12:48 PM
