House Colder After Spray Foam Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-10-2014, 05:43 PM   #1
House colder after Spray Foam Insulation
I recently had the batt insulation in my rim joists replaced with spray polyurethane foam. I also had 12" of loose blown cellulose added to the attic over the existing batt insulation. My problem is my basement is considerably colder than it was before the spray foam was done. They removed the batt insulation before they added the spray foam. I had this professionally done. Any ideas what is wrong?
dlf622 is offline   Reply With Quote
Old 01-10-2014, 06:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Nothing.
Nothing about the rim joists being sealed should make the basement colder.
Are you sure the vents in any of the duct work are in the same positions?
The air may be more "static" now as a result of the reduction in loss from the poorly sealed bands which, in turn, could have slowed the movement of air into the basement...? Its a theory but most band joints allow for the air infiltration into the basement areas.
Old 01-10-2014, 06:11 PM   #3
Rewards Points: 13,250
And how did you figure that?
Did you take the inside and outside temperatures before and after when the outside was the same temp.?
Old 01-10-2014, 06:32 PM   #4
I didn't take temps before or after. .. I think the vents are in the same position. I'm not sure what you mean poorly sealed bands ... do you think the contractor did a bad job?
Old 01-10-2014, 06:44 PM   #5
Not sure we would know without a few pictures.
The whole idea of an insulated basement ceiling is to close up the house envelope to reduce the heat loss inside the house.
Less heat going into the basement the colder the basement is.
Old 01-10-2014, 06:53 PM   #6
hmm .. sorry for my ignorance, but I would have thought that if the basement was warm prior to the insulation, it would even be warmer with the spray insulation. They only did the rim joists, the ceiling is not insulated.
Old 01-10-2014, 07:50 PM   #7
It should be.
I can't see any reason, beyond a tighter structure allowing less conditioned air down there.
Old 01-10-2014, 09:55 PM   #8
Registered User
Rewards Points: 5,204
It is more than theory- but fact that rims allow air in/out; http://www.buildingscience.com/docum...l_seal_rev.pdf
http://www.buildingscience.com/docum...d-but-strange/
Stands to reason, the new attic insulation is the culprit, not the rim insulation, IMHO.
Did you check if they extended the soffit intake baffles above the new insulation? If not, any holes/chases from plumbing pipes from the basement are now supplying the starving exhaust vents with warmed basement air- as warm air rises through the basement floor- if they didn't check if air sealed previously. Were the basement top plates of interior walls air sealed, especially plumbing drain vent pipes that run to attic and beyond?
May want to check your ceiling drywall thickness/on center spacing; https://docs.google.com/viewer?a=v&q...h3VLQNBaXp54rA
Gary
PS. Welcome to the forums!
Old 01-10-2014, 10:50 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
possibly your furnace is on less there by warming the basement less?Assuming thats where it is?
Tom Struble is offline   Reply With Quote
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
danpik (01-13-2014), Gary in WA (01-11-2014), Windows on Wash (01-12-2014)
Old 01-11-2014, 07:53 AM   #10
Didn't think of that. That is certainly part of it. Even a completely sealed duct system, the radiant heat difference will have an impact.
Old 01-11-2014, 07:29 PM   #11
Registered User
Could be, Tom. Good thought!
Gary
Old 01-13-2014, 01:11 AM   #12
After using a spray Most damaging moisture within a building envelope cavity is the result of warm moist inside air being exchanged with the cold dry outside air within the walls. As the moisture in the air condenses, it forms dew within the insulation. Because foam insulation is an air seal, this moisture movement and condensation does not occur. It is ideal for use in climates where buildings are both heated and air conditioned because the situation is reversed in summer with moisture forming on the back of the interior vapor retarder.
michelclarke is offline   Reply With Quote
Old 01-13-2014, 09:41 AM   #13
....hmmm...
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (01-14-2014)
Old 01-16-2014, 11:03 PM   #14
The best way to insulate the room would be to have it sprayed with closed cell insulation. That would provide a moisture barrier, seal any air leaks as well as provide insulation. Closed cell doesn't absorb moisture so mold isn't a problem and it has an R value of about 8 per inch! Having a professional do it wouldn't be cheap upfront but certainly would save you money in the long run. You can buy do it yourself kits but I'm not sure how easy they are.
spray foam insulation jbillups Insulation 2 01-10-2014 08:50 AM
Spray Foam insulation under roof decking federer Insulation 30 10-29-2011 10:22 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 08:12 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 11:14 AM
