HOT Attic!! - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 10:44 AM   #16
Rewards Points: 956
Originally Posted by AGWhitehouse View Post
prime and paint the gwb for the class III vapor retarder i believe is required in your area.
what is gwb? should i use glossy paint or is latex sufficient?
federer is offline   Reply With Quote
Old 10-20-2011, 11:30 AM   #17
AGWhitehouse's Avatar
gwb=gypsum wall board, also known as sheetrock.
glossy paint can be latex, oil based, or epoxy. glossy is the finish type, not the paint type.
Yes latex primer and paint are sufficient.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-20-2011, 01:24 PM   #18
Rewards Points: 956
thanks for clarifying. yea what i meant was would glossy finish be better because aren't one supposed to use that in a bathroom where there is much more humidity vs basic latex finish.
Old 10-20-2011, 01:39 PM   #19
Not necessarilly. "basic" paint finish is called "eggshell". Glossy finishes aren't significantly any more resilient to moisture than other finishes. The difference is really in the maintenance. Glossy surfaces don't grab dirt as easy and are therefore easier to clean.
Paint finishes: http://www.wisegeek.com/what-are-the-different-types-of-interior-paint-finishes.htm
Old 10-22-2011, 09:45 AM   #20
Registered User
Rewards Points: 5,524
OP, sorry for the thread hi-jacking. Your location in NC makes a difference for the minimum insulation required per code, 3 different zones, find yours: http://publicecodes.citation.com/ico...001_par001.htm
Then find the ceiling requirement: http://publicecodes.citation.com/ico..._11_sec002.htm
Gary
Tags
attic insulation , insulation
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
