High Cost Of Insulation In Ontario - Insulation - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 01:39 PM   #1
High Cost of Insulation in Ontario
I'm about to insulate my attic with OC R40 fiberglass bats. The price of a 48 sq ft bundle at my local Home Depot (Toronto) is $59.77. In Gloucester (Ottawa area) it is $41.25.
Does anyone have experience in making Home Depot match their prices? This Toronto price is 50% higher, and it represents about $400 on my project.
GuyBooth is offline   Reply With Quote
Old 01-23-2012, 02:03 PM   #2
Rewards Points: 6,652
Blown in is better than batts. You will find that you are wasting money putting batt insulation in the attic.
Old 01-23-2012, 05:31 PM   #3
Gregzoll, thanks for replying, but with all due respect - your reply bears no relation to my question. My choice of insulation is based on much thought and many factors. But I want to know why prices in one location are so different from prices in another, and how to negotiate them in my favour.
Old 01-23-2012, 05:40 PM   #4
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Homedepot will not match the price unless it is a local store.
As to the negotiating in my xp they are less then able to help in the store. But if you find the same insulation locally and get a quote they will match it without question.
Big N8 is offline   Reply With Quote
Old 01-23-2012, 05:43 PM   #5
Home Depot is in the business to make money. If you want to negotiate prices, consult with a contractor that does nothing but insulation. They will tell you the same thing I told you, that batts do nothing for insulating the attic space, to help make the living space better in comfortability, and that Blown-in is the best way to go.
Costs will be lower with blown-in vs. batts, once you start looking at the bottom line.
Old 01-24-2012, 07:18 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Go with cellulose anyway.
+1 to the blown in recommendation.
Old 01-24-2012, 04:31 PM   #7
011010100110111101100101
Rewards Points: 160
I'm not an insulator, however I recently bought a ton of insulation (like 60 batts). I found that home depot reduced the per-batt price by around $5 each for bulk purchases over 10 units.
I, like you, used batts because I didn't want to have to staple up a moisture barrier, then rent the machine to blow it all around, and measure it to make sure I get the height correct for R38 full height (including over the wall cavity). Perhaps it would have been a non-issue for a pro, but I wasn't about to hire someone.
-- Joe
anesthes is offline   Reply With Quote
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 05:19 PM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 11:31 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
