Help With Foundation Insulation Due To Water - Insulation - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 10:10 AM   #1
Trucon01's Avatar
Rewards Points: 510
Help with foundation insulation due to water
Hi All,
In my never ending battle with finishing my basement, while ripping down the "brand new" bathroom "they" built, I found substantial mold and moisture.
The bathroom is in the front left of the townhouse. The inside corner seems to have a slight leakage issue. However, if you notice in the picture, there is a crack in the brick, right where the water issue is inside.
I would love to dig that corner up outside and take a peek, but if I do, I'd like to know the best way to seal it. I've seen a black tar like substance on other houses as well as a dimpled membrane, etc.
If there is anything else I should be looking for or be doing, please let me know. Otherwise, just let me know what my steps are after digging up the front corner of the house.
Enjoy the pics
Help with foundation insulation due to water-photo.jpg   Help with foundation insulation due to water-photo-4.jpg   Help with foundation insulation due to water-photo-1.jpg   Help with foundation insulation due to water-photo-2.jpg   Help with foundation insulation due to water-photo-3.jpg
Trucon01 is offline   Reply With Quote
Old 05-03-2012, 12:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,098
Are you sure the moisture is from outside to in?
Very common to see moldy walls in basement bathrooms as a result of moisture that is leaving from inside to out?
Unless you see evidence of bulk moisture transfer (i.e. pooling after rain, efflorescence, staining, etc), a foundation crack does not always = a leak.
That is likely a brick veneer and the actual wall (as indicated by your pictures) is a CMU block foundation that appears to be intact.
The mildew and mold is about 99% likely to have come from the shower and the condensation potential as a result of the drastic temperature spread.
Old 05-03-2012, 01:00 PM   #3
Trucon01's Avatar
Rewards Points: 510
That is interesting and a great possibility. The fan they had in the bathroom sucked and wasn't properly attached to the vent outside, which was right in the area where the mold was found. And since the vent was not attached properly, the moisture picked up was dumped between the drywall and concrete...
However, when I ripped down the studs, the concrete block did look wet in that area and there hasn't been any showers in over a year (since I've bought the house)...
How else can I check to see if its an inside or outside thing? Take a hose and leave it on outside dumping water down for 20 mins?
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 10:51 PM
Water against foundation AhSo Landscaping & Lawn Care 11 09-21-2009 06:13 AM
Water near foundation AhSo Landscaping & Lawn Care 3 09-14-2009 05:53 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
