Help With An Exposed Insulation Issue - Insulation - DIY Chatroom Home Improvement Forum
Old 05-30-2013, 03:52 PM   #1
Help with an exposed insulation issue
Hi all,
I have an issue with exposed insulation in my basement.
I've attached pictures--how big of a problem is this? I bought my house in this condition; the home inspection did not flag this as an issue (which is odd because I thought that exposed fiberglass was a health issue).
Can you guys give me a diagnosis and maybe a possible solution?
Thanks!
dougcruze is offline   Reply With Quote
Old 05-30-2013, 03:57 PM   #2
Rewards Points: 13,450
I'd be more concered with the fire hazzard, damage being done to it by being left exposed and the insulation molding up with no vaper barrier and being in direct contact with the foundation.
Old 05-30-2013, 10:01 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
Don't disturb it of cover it with Tyvek.
What is all the black material on it? Is it up against the foundation wall like Joe was mentioning?
Old 06-02-2013, 09:29 PM   #4
Registered User
Rewards Points: 5,482
Asphalt paper-faced f.g. batt (over 25 flame spread index) requires a covering such as drywall or plywood, solid T&G boards, etc.; http://publicecodes.cyberregs.com/ic...9_3_par067.htm
Notice foil-faced and asphalt faced do not pass, require covering; http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
Tyvek in a basement is not acceptable either, it will burn/melt to expose material below; #3; http://www2.dupont.com/Tyvek_Weather...rchitects.html
Gary
The "biggest loser" in fiberglass insulation.... Gary in WA How To Guides 2 01-20-2015 06:19 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
