Help Asap! Best Insulation For A Bath/exterior Wall? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 09:33 PM   #1
help asap! Best insulation for a bath/exterior wall?
I'm remodeling my bath and I took everything down to studs. There was foil-faced fiberglass insulation in there before but I'm not sure what to put back in there.
I've looked at Owens corning and johns manville's websites and neither is very helpful.
What's the best? Kraft-faced fiberglass? Foil-faced foam panels (Tuff-R)? Something else?
NJoytheRide is offline   Reply With Quote
Old 04-29-2011, 10:44 PM   #2
A Little Of Everything
Rewards Points: 1,364
Hey Bud - here's a link to a discussion that was had about this, some time ago.
Bathroom Vapor Barrier
If it were my project, I'd use un-faced insulation in the exterior walls, then install a good vapor barrier.
DrHicks is offline   Reply With Quote
Old 04-30-2011, 06:39 AM   #3
Take a look at 'Roxul' insulation, a fairly new product. Insulates for heat/cold and noise. Insulate all 4 walls to keep it warm and quiet.
Old 04-30-2011, 09:48 AM   #4
Thanks for the quick replies guys. As I'm reading responses, I'm finding that my concerns are not just about the insulation,but also the vapor barrier.
I've read on some of the threads here that some people argue that a plastic vapor barrier over insulation will trap moisture between the exterior tar paper on the house, and this new layer, so that should not be done. That's why people say to use the Redgard.
Last night I found the NJ Residential construction code here:http://ecodes.biz/ecodes_support/fre...nstruction.pdf
and I'm interpreting it as I have options.
Here's what I was planning on doing, please tell me if I'm missing something:
1. (still need to pick an insulation)
2. apply Durock fiberboardon all walls, and also installing a "Ready Niche" above the bathtub.
3. cover all seams with fibritape and then mortar
4. apply Redgard to all durock surfaces
5. caulk the seams between durock and bathtub.
6. thinset, tile, and grout (all rolled into one)
7. Finally coat all tile with a Sealer
Also, please check out this video of the wall (you won't be rick-rolled, I promise):
http://youtu.be/VMWZl7L-B28
Old 04-30-2011, 10:55 PM   #5
Rewards Points: 1,092
Be careful w/ a true vapor barrier; all walls should be able to breathe in at least one direction, preferably two. I do not see a VB in any of the drawings in Joe Lsitburek's book "Builder's Guide to Cold Climates" and I know they are being frowned upon on exterior walls, even in the coldest climates. Use cement board, w/ a liquid applied water proofing.
Old 05-01-2011, 07:30 AM   #6
Rewards Points: 154
i would be spray foaming with a closed cell foam
awdblazer is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
