Heavy Draft Under Cast Iron Baseboard - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By Yodaman
Old 01-10-2017, 09:53 PM   #1
Rewards Points: 40
Heavy draft under cast iron baseboard
I live in an older home so I know drafts are going to happen. There is however a strong draft coming from a 4 foot-ish section under one of the cast iron baseboards.
Ive posted a pic but you really cant see much. I know these types of things are annoying to remedy, but what if I just shot some 'great stuff' into the gaps?
Safe? Effective?
JSDNJ is offline   Reply With Quote
Old 01-11-2017, 06:36 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 822
Re: Heavy draft under cast iron baseboard
Probably just as easy to rip some Roxul or other dense fibrous insulation and stuff into the gap.
I am not a fan of shooting foam unless I know where it is going or what it will be against.
Bud9051 likes this.
Old 01-11-2017, 07:44 AM   #3
Rewards Points: 3,204
How big is the gap and will the foam or whatever be visible after repaired. Foam that isn't enclosed inside some cavity and protected from the light (uv I believe) will deteriorate and shrink.
Options might be caulking or caulking covered by a piece of trim. If it is a larger gap then they have fillers that can be used first.
Like Windows I hesitate to use the can foam.
Bud
Bud9051 is offline   Reply With Quote
Old 01-11-2017, 11:36 AM   #4
Rewards Points: 12,790
Balloon wall construction?
Basement or crawlspace been air sealed?
Rim joist insulated?
Floors been insulated?
Old 01-11-2017, 12:48 PM   #5
Property Mgt/Maint
Rewards Points: 348
If the crack is bigger than your pinky finger, stuff some foam backer rod in there prior to caulking. Use a siliconized door and window caulk like Dynaflex 230 or equal.
The backer rod comes in about any size you need.
http://www.homedepot.com/s/foamm%252...2520rod?NCNI-5
Dave Sal likes this.
Yodaman is offline   Reply With Quote
Replace cast iron stack. Clutchcargo Plumbing 1 02-18-2013 10:19 PM
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 03:17 PM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 01:37 AM
cast iron or pvc treerat Plumbing 1 03-29-2011 07:38 AM
Cast Iron Baseboard Installation Bob G. HVAC 7 09-15-2009 09:22 AM
