Hardi Board - Insulation - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 09:09 AM   #1
hardi board
can i instal hardy board over foil faced polysio sheathinh
evelyn davis is offline   Reply With Quote
Old 05-28-2012, 09:10 AM   #2
can hardy board be installed over foil faced polyiso sheathing
Old 05-28-2012, 10:13 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
yes,but a drainage space is recommended in cold climates where there is no interior vapor barrier
see pg 3
http://www.jameshardie.com/pdf/USTB_...s-Hardie-2.pdf
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (05-28-2012)
Old 05-28-2012, 02:13 PM   #4
Registered User
Rewards Points: 5,490
Foil-faced f.b. is recommended for a hot humid climate, pp. 5: http://www.buildingscience.com/docum...ting-sheathing
Your location makes a huge difference on foamboard thickness, rainscreen or not, faced or not, etc.....
Gary
Gary in WA is online now   Reply With Quote
Old 05-28-2012, 04:22 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Rainscreen wall designs are preferable regardless of climate region in my opinion.
+1 to a foil faced FB in hot humid climates on the exterior wall.
Old 05-29-2012, 06:31 PM   #6
Gary
question was can hardie be installed over foil face polyiso,hardie says yes with the following stipulation
Old 05-29-2012, 06:40 PM   #7
I know alittle about alot
JWilliams850's Avatar
you tell them mr struble
JWilliams850 is offline   Reply With Quote
Old 05-31-2012, 12:42 AM   #8
Registered User
As Hardie defines where/how to install their product, it may be helpful to ask where a new member lives for insulation guidance or discussion, eg. no faced f.b. in a cold climate with poly sheeting already installed on the interior under drywall.......(the dreaded) two vapor barriers. Since foil-faced was posted, I presume a colder climate..... though I've been wrong before!
On a side note; A "rainscreen" system is not needed in a hot-dry or mixed-dry according to building science, page 5 (again) the lower map titled "Exposure" (blue shades) in my post #4 link.
Under 20" annual rainfall locations wouldn't benefit enough to pay for it (in my opinion), another map to only 16": http://maps.howstuffworks.com/united...infall-map.htm
only "where it rains"; http://www.buildingscience.com/docum...and-air-spaces
Gary
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 04:13 PM
can we install cement board(wonder board) sajidshah Flooring 20 09-17-2009 10:40 PM
Hardi board plank siding over T1-11 bluefitness Building & Construction 3 12-19-2008 07:55 AM
