Great Stuff Fireblock - Insulation - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 12:45 PM   #1
I'm sealing gaps around my furnace vent that goes from my garage up through my house to the roof. I was going to use fire caulk for this but the gaps are a little big for that. Does anybody know if 'Great Stuff Fireblock Foam' sealant would be a good for an application like this? It doesn't really state on the can that it is for high temperatures like the caulk does. If not, does anybody have another suggestion? Thanks!
thedudeabides! is offline   Reply With Quote
Old 03-19-2012, 12:56 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Metal coil + the caulking.
FYI, that caulking is very heavy and viscous. You can lay down a very good sized bead and cover a bunch but don't under by ad the yield is not that great on the tubes.
Old 03-30-2012, 04:01 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Fire caulk and fire stop foam materials are not designed for sustained high heat. They are made to stop fire. The foam will char on the surface when exposed to fire. The char then protects the rest of the foam undeneath from the effects of the fire. Fire caulk can work the same way or it can expand under high temperatures to fill a void and prevent fire penetration. You don't want to use products like that in a situation where they will be constantly exposed to high heat. Fire stop sealants are not really good for exposure to the weather either.You need a high temperature sealant. Many of these are silicones and are designed for sealing exhaust stacks through roofs. A gas furnace sales place should have some.
My Great Attic Renovation GFPC85 General DIY Discussions 1 02-09-2011 05:21 PM
Great stuff or equivalent product for cold weather? Red Squirrel Building & Construction 11 01-21-2011 11:19 AM
flashing: how to tell the good stuff? jeauxbleaux Roofing/Siding 6 08-21-2009 11:24 PM
Black stuff under thinset? Osiris Flooring 1 04-04-2009 05:09 PM
Bookcases in a Great Room divadoc Interior Decorating 7 01-17-2008 09:02 PM
