Glue XPS Together For Extra Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 12:23 PM   #1
Glue XPS together for extra insulation?
So I originally put 1/2" xps around the basement (walkout) and framed against that because I didn't want to lose the extra couple inches of floor space using 2" xps. Now I'm second guessing myself wondering if that is enough to keep the concrete warm during the cold months (Nebraska). I planned on using R-13 unfaced fiberglass in between the studs, but I wonder if water will still condense on the xps.
What is the downside of putting an additional 2" of xps in between each stud cavity instead of the fiberglass?
NEW-B is offline   Reply With Quote
Old 04-09-2011, 12:41 AM   #2
Registered User
Rewards Points: 5,216
Good idea.
Foam is better, far as thickness, pp. #9; http://www.eere.energy.gov/buildings...s/db/35017.pdf
Minnesota heating degree days= 8253 Lincoln, Nebraska= 6278
The downside..... only possible air spaces for convective loops if any leaks are there..... I would foam seal the pieces between studs, use left-over for rim joists, and use Airtight Drywall Approach (ADA) on the drywall after pulling the batts in 1/2 to fit the 1-1/2" spaces.
http://www.buildingscience.com/docum...wall-approach/
Gary
Old 04-11-2011, 03:07 PM   #3
Originally Posted by GBR in WA View Post
Good idea.
Gary
I think thats what I'm going to do. I noticed that there was a thin clear film on the 1/2" xps that I bought. Does that need to be removed or can I just glue the other board right on top of it?
Old 04-11-2011, 08:26 PM   #4
Registered User
More reading for you! pp.7-10 and fig. 12; http://www.buildingscience.com/docum...lation-systems
Gary
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 09:17 PM
How to glue on insulation to heater cabinet? darsunt HVAC 4 10-23-2009 12:37 PM
re: glue together 1" sheets of extruded insulation gramps416 Building & Construction 6 01-07-2009 07:08 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
