General cellulose question for the experts!
I have been reading an awful lot about cellulose insulation, and there seems to be some confusion as to how everything works. Watched videos, read many web pages and so on. I have never personally used cellulose, hence my questions here.
It seems that cellulose when installed using the dense pack method is claimed to be an effective air barrier. This claim seems to come from either the installers or the manufacturers. Others seem to disagree saying that without some other form of barrier the cellulose will not be an effective air barrier on it's own. This obviously applies to wall cavities and not ceilings. What say you? Now, as far as blowing cellulose into attic spaces, two things appear to be obvious, at least to me. Firstly, it is difficult to get an even thickness and secondly, because of the loose fill nature of the product, there would seem to be any number of cavities which could conceivably leave open spaces for heat to escape. Educate me please on how these items are addressed. Thanks. :) |
i don't see cellulose as being an air barrier. unless you "pack" it solid in there.
in my experience, yes, an "even" layer is difficult. though i am sure pros have the experience to make it pretty even. but it doesn't have to be even, just get it reasonably close. blow enough and you will be good. |
oh. the "nooks and crannies" . blown cellulose has a talent for getting into everything.
OTOH it will apparently "skin over" in some circumstances, making it the superior choice for blown in attic insulation over chopped fiberglass. Thank you for your comment, I do appreciate it. :thumbsup: |
Thank you again. |
As effective as spray foam, no. Don't ever install cellulose in a non-vented roof design. It does not work well and you will have a nightmare on your hands. It is near impossible to get an exactly level application of any loose blow insulation but I don't think that really matters. It is about getting it up to a minimum established level (i.e. whatever value you want) and it does fill in void spaces quite well. |
I agree with you about the poly vapor barrier. Air tight, it works great and will be much tighter than cellulose that is dense packed.
In a non-vented design you would dense pack it dry. There are just too many examples of sheathing and structure rotting out with a cellulose insulation schedule to trust it. It is hygroscopic and will draw water to it. I know that it is not indicated for humid climates or coastal applications but I have yet to personally observe and issue and we live in a very humid and coastal climate. |
As you want sources...lol;
convective loops in f.g. at low temps: sensationalized;http://infrared-energy.com/files/Spe...onProblems.pdf the testing- and a follow-up one, remember this is a low density (0.5#) blown-in, bonded/cubed fiberglass; http://docserver.nrca.net/technical/401.pdf In defense, and not found in f.g. batt; https://docs.google.com/viewer?a=v&q...mAAqxY_9UrVORg Lawsuit against the "Thermacube" type; http://www.homeenergy.org/show/artic...zine/77/id/910 Another summary and testing of cellulose results: http://www.homeenergy.org/show/artic...zine/77/id/910 Unbonded blown-in f.g. and the big spread of air-permeability ratings for different densities, pp18, table 2; http://www.ornl.gov/info/reports/1994/3445603820925.pdf Use this (conversion calculator) to convert the density; http://www.unitconversion.org/densit...onversion.html Interesting read; http://jen.sagepub.com/content/26/2/153.abstract Cellulose thermal properties testing; http://www.osti.gov/bridge/servlets/...ble/390620.pdf (long time to download) Material B- 9.4 (0.58# f.g.); http://web.byv.kth.se/bphys/reykjavik/pdf/art_085.pdf The density of an insulation sets its air permeability. https://docs.google.com/viewer?a=v&q...M8l_EeA2F-qvvA Cellulose is blown in attics at 1.5# density while f.g. is around 0.55#; http://ws680.nist.gov/bees/ProductLi...Fiberglass.pdf not much mass there... http://docs.google.com/viewer?a=v&q=...Sl4MDm_aao1YUg How about adding more blown-in f.g. to stop the convective loops, or 2" of cellulose? https://docs.google.com/viewer?a=v&q...SWhJRhM2V4M5EQ Moisture; http://www.diychatroom.com/f103/blow...-think-163287/ Gary |
Gary, as always, you are an absolute gold mine of information. So yet again, thank you most sincerely.
LOL. To all members: the white "search box" at the top of every page will bring a multitude of posts on the subject entered; eg.- "cellulose insulation in attic" gives: http://www.diychatroom.com/search.php?searchid=3612201
Though it usually doesn't answer the more technical questions, at least not with the latest answers... I do get carried away on certain subjects, lol. Gary |
what is 4.0 densities ?
when i said "pack it in there". i mean, to the point that it will hold a shape while standing on its own. |
This is interesting, I see why you wanted to know about the insulation now.
"I have spent the past several weeks trying to design a small net zero energy house and the v.b. and thermal bridging are two of the most important aspects of such a design." I hope you post about your small zero energy house that will be really interesting. I use to read the "Mother Earth News" for all of the great information about so many subjects, one being insulation and different ways to build an energy efficient home. One question you asked earlier about the cellulose, it is wet when blown in the walls. My insulation subs would spray a 1/2 of foam on all the exterior walls for a vapor barrier, then the cellulose. If you want a great sound barrier around the bathrooms, cellulose is fantastic as a sound killer. Gary, now I never will get through reading.:) |
| All times are GMT -4. The time now is 05:57 AM. |
