Garage Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 07:33 AM   #1
Rewards Points: 326
Garage Insulation
Hi All,
Has anyone insulated their garage? my garage is some what in my house. Such that we have one bedroom floor that is partially over the garage ceiling.
I have left over FG blankets and FG batts cutouts from my basement, I was thinking about using them in the garage, as oppose to throwing it out.
We already top-upped the attic to an r-value of 60. (might have settle to 50 now).
Amitabh is offline   Reply With Quote
Old 03-31-2014, 10:30 AM   #2
Anything you can do to air seal and insulate the garage will certainly help.
Honest Bob is offline   Reply With Quote
Old 03-31-2014, 03:57 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,002
Post up a picture of the garage attic and you will get more feedback.
Old 03-31-2014, 10:15 PM   #4
Registered User
Rewards Points: 5,466
The garage ceiling should be covered with Type X 5/8" drywall and foamboard under that if you wish, Fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Old 04-01-2014, 09:05 AM   #5
I would recommend insulating with a combination of foam board and closed cell spray foam. You can put the foam board up first, then apply 1" of spray foam over it. That will give you a much higher R-Value than fiberglass, stop air leakage, and prevent condensation. Our company's spray foam kits also prevent mold growth.
Getting an air tight seal will make a world of difference. The space will be much warmer, and it will keep odors from the garage our of your living space.
For more information you can check out the awesome guide that Gary in WA shared.
GreenFoamFan is offline   Reply With Quote
Garage insulation.. sh40674 Insulation 4 01-09-2014 09:38 AM
Finishing the garage with insulation and drywall. Snapper12 Insulation 2 10-24-2012 06:14 AM
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 02:57 PM
Garage Door Insulation PaliBob Building & Construction 4 03-27-2009 03:05 PM
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 08:18 AM
