Garage Insulating Ideas - Insulation - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 06:20 AM   #1
Garage insulating ideas
Hey guys! First post so please bare with me
I live in Vancouver BC
I have a full size 2 car garage, unfinished, with a vaulted roof for added storage spade as an attic
Looking for some ideas on the most cost effective yet efficient & functional way to insulate the whole thing. Walls and ceiling.
Any help would be greatly appreciated
Thanks in advance!!
OnlyOneKeano is offline   Reply With Quote
Old 03-26-2012, 09:26 AM   #2
Too Short? Cut it Again!
Spray foam is one option if you can get someone out for a relatively small job. Otherwise fiberglass (or other material) rolls or matts for walls and between ceiling rafters. Seal around windows and make sure the garage doors are weatherstripped, etc. A ceiling would help insulate the garage space from the ceiling vault. You don't want to use foam sheets unless you plan to drywall as they are not fire rated.
You need to decide what R value you hope to achieve to determine cost and feasibility. I assume you work in the garage a fair amount and are not just trying to keep the Bentley and Rolls comfy in winter?
Old 03-26-2012, 11:20 AM   #3
Rewards Points: 252
As sdsester said, it depends on your goal. Since it sounds like it's just a place to park your cars, fiberglass batts would be your best bet.
shazapple is offline   Reply With Quote
Old 03-26-2012, 11:50 AM   #4
"just trying to keep the Bentley and Rolls comfy in winter?"
Haha I wish! More like the jeep and the prelude lol
But yeah I do work on my cars etc in garage often enough that I'm starting to get tired of the uncomfortable temperature
Have you heard of using expanding foam in between the studs and in all tue little nooks & crannies & then fibreglass on top of that?
Old 03-26-2012, 12:07 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Yes.
That would be considered a kind of flash and batt style approach.
You should seal all the penetrations, gaps, and cracks in the outside wall and then insulate.
This can be done with foam or sealant/caulking.
Old 04-07-2012, 02:11 AM   #6
how do i determine/figure out what R-Value I want?
Is there a such thing as over-insulating which could cause condensation?
My garage is well finished on the outside with the vapour barrier throughout.
Basically I do not want to spend alot however I want to do an adequate job as well. I certainly don't want to regret not spending enough and at the same time I dont want to go all overkill (like I do with alot of things) and end a couple grand in the hole lol
thanks again
Insulating the attic space above my garage demodude Insulation 1 01-29-2012 01:24 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
insulating a garage daviesrk Building & Construction 1 11-04-2010 06:39 PM
Insulating Garage / Workshop with Free Foam? PaulBob Building & Construction 2 12-05-2008 05:12 PM
