Garage Door Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 05-01-2014, 01:44 PM   #1
Briogaid Dearg
Rewards Points: 27
Garage door insulation question
I have an attached garage and my bedroom sits above it. In TX summer heat my garage get very hot which makes my bedroom the hottest in the house.
I am looking at some reflective insulation at Lowes http://www.lowes.com/pd_13357-56291-...ier&facetInfo= (id have to buy several rolls)
and this http://www.lowes.com/pd_358650-199-1...ier&facetInfo= (pre cut and one box will do a door)
Which would you recommend or is there something different ? I cant tell with these products but from online pics I see one side may be white or both sides may be aluminium. If one side is not aluminium is that what goes to the door, right ?
originalhandy is offline   Reply With Quote
Old 05-01-2014, 06:23 PM   #2
Rewards Points: 14,306
Can be lots of other things causing it to be so hot.
Builder love to cheat out on the amount of insulation in a garage ceiling and not air seal or add a vapor barrier.
How much insulation is in the attic?
Is there a ridge vent and soffit vents?
Is there knee walls, and how are they insulated?
Old 05-01-2014, 11:04 PM   #3
Briogaid Dearg
Rewards Points: 27
There is about 12+" in the attic if I remember. The attic is soffit vented and im not sure about ridge vents, the rest of my house stays at good temps. There are knee walls.
Sent from my SCH-I535 using Tapatalk 2
Old 05-03-2014, 11:00 PM   #4
Registered User
Rewards Points: 526
Another option, fig.7; http://www.buildingscience.com/docum...n-crawlspaces/ then sleepers, 5/8" Type X drywall, air sealed; http://www.buildingscience.com/docum...wall-approach/
Gary
Old 05-03-2014, 11:28 PM   #5
Rewards Points: 30
I live in Minnesota and have used this insulation to insulate my garage door. I could not be happier with the finished door. My garage is now much warmer in the winter and not as hot in the summer. In other words it works good. I recommend it!
http://www.texasgarages.com/akit.htm
SHR Plumber is offline   Reply With Quote
garage addition question robertstbl Remodeling 14 02-05-2014 02:19 PM
Garage Floor Slope Question shiyang100 Concrete, Stone & Masonry 5 02-04-2014 12:39 PM
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 12:30 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
