Garage Ceiling Insulation Worth The Cost? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 10:08 PM   #1
sparks1032's Avatar
Garage ceiling insulation worth the cost?
I am heating my garage that has insulation in the walls not the ceiling and after doing some math the cost of just regular fiberglass insulation is around $500. I don't heat it all winter just happen to want to finish a painting project.
Will I make this money back anytime soon? Or should I not bother....
sparks1032 is offline   Reply With Quote
Old 01-13-2012, 10:11 PM   #2
Rewards Points: 13,274
Most of your heat is lost through the ceiling, windows and doors.
Must be a big garage to have it cost $500.00. for materials.
How many sq, ft. is it.
Old 01-13-2012, 10:19 PM   #3
sparks1032's Avatar
It is not ALL garage as some is living space but 20 by 20 area then a 10 by 25 area 650 square feet at $35 a roll attic insulation was my guestimate
Old 01-13-2012, 10:24 PM   #4
Rewards Points: 940
blow some cellulose up there. Shouldn't cost much.
Teach a man to start a fire and he'll stay warm for a while.
Set a man on fire and he'll be warm for the rest of his life.
cleveman is offline   Reply With Quote
Old 01-13-2012, 10:28 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,862
Blow some cellulose up there.
Old 01-14-2012, 11:11 PM   #6
sparks1032's Avatar
Two votes because it will cost less or work better? I am confused a bit?
Old 01-14-2012, 11:33 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Andy.
AndyGump is offline   Reply With Quote
Old 01-15-2012, 09:34 AM   #8
Remodeling Contractor
Blown cellulose of injection foam (works much better) will work. Is it worth the cost? Absolutely. Payback in energy savings is 5-7 years. cost is $2 - $3.50. This cannot be done as a DIY project. Small rental blowers for cellulose will not dense pack, thus very little insulation value will occur. Both methods require professionals but are worth having it done.
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
Garage renovation/vaulted ceiling & removing "ceiling joists" brandonlaundry Building & Construction 7 02-20-2011 12:27 PM
basement with garage insulation question WS6transAm General DIY Discussions 7 01-21-2011 07:15 PM
Installing a Ceiling in a Garage oldbuffer Building & Construction 8 06-09-2009 10:00 AM
