Garage ceiling insulation
Hi all, first time poster! I did a few searches, but haven't found an answer to what I'm looking for, so hope y'all can be of assistance.
We have an older detached garage built in the 60's that we're wanting to convert into a gym/workshop space to use year-round. I've started off by insulating the walls and putting up drywall, but am at a bit of a loss as to what to do with the ceiling. I want to keep the cathedral-style ceiling because I'm fairly tall and wouldn't be able to run on a treadmill or jump if we just closed off the rood - but the joists that run up the roof are 2x4's - meaning I can only fit R-13 faced insulation between them? I'm not 100% sure. I'd love to fit thicker stuff between them, but I know I'm not supposed to compress the insulation. Anyone have any ideas on how to get the best bang for my buck insulation-wise up there? I was also planning on cutting some soffit vents into the side and running channels up behind the insulation to get some airflow in there - but with only 3 1/2"-4" to work with, that really limits the space I can use. Ideas? Thanks all! Please direct me to any existing threads if there any on this, in case I missed them too! |
How are you going to be conditioning the space?
2x4 @ R-13 is about 1/3rd of what is required and even less of what is recommended. http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html |
Thanks for the reply! I realize that R-13 is too little, and I'm wondering what else I can do with the space I have? I really do want to keep it cathedral-style (I hope I'm using the right term there) because if we close off the ceiling, I'm pretty tall and won't be able to use the space as well as I'd like to.
If I use thicker insulation, and it sticks out from between the joists but is held in place by a plastic sheet that would be used as a vapor barrier - would that work? Does the insulation have to fit in between the joists? |
How are you heating the space and how do you want it finished?
You don't need to have a drywall ceiling but you will need a proper air barrier across that ceiling to prevent the warm air and diffusion of moisture to the underside of the roof deck. |
The right way to do it would be add collar ties to act as a ceiling at a height you can live with, add 2 X 2's to the bottoms of the rafters, Add foam baffles from where the ridge vents will be to the point where the collar ties are.
Now you can add the R13 and not compress it and still have air flow. On the flat part of the ceiling you could go as thick as you want to. You also going to need to add a ridge vent so the hot air can escape in the summer. If you install insulation tight againt the sheathing it will super heat the shingles and shorten there life by about 5 years and the heat in the summer will transfure down into the room. By having that flat raised ceiling you could add can lights or a ceiling fan. |
Unvented assemblies that leak moisture with shorten roof life in general but there is nothing to indicate that shingle life suffers. |
90 % of my work is remodeling in older houses 100 years old or older. Dozens of times I've seen where over the year DIYS have gone in there and tryed packing in the insulation to tight with no soffit vents, no baffles and no ridge vent, The paper on the insulation got so dry out and had gotten so hot it was falling apart, the 10 year old architural shingles would crumble in you hand and the granuals just filled the gutters.
http://www.gaf.com/Roofing/Residenti...r-signals.aspx Notice how they show at least 4, differant pictures of what poor venting can do. |
Poor ventilation in a vented assembly and a hot/insulated roof deck are two totally different things.
Shingle manufacturers will forever attempt to blame the conditions and not the shingle. There is no data to indicate that an insulated, sealed roof assembly shortens shingle life. Most shingle cooling happens to the exterior and there are studies showing only a 5-7° difference in peak shingle temperature in Las Vegas. Ventilation and moisture drive to the back of the shingle can kill it early. |
Hi all, thanks for all your help with this. I'll most likely go the route of adding collar ties to set a higher ceiling height, and work from there. Thanks!
No shingle manufacturer, roof inspector, or qualified roofer would ever tell you that it is ok to insulate against the deck without ventilation. Heat causes breakdown of anything in any application, so why are shingles any different?
This is a literature review by the Florida Solar Energy Centre. It does not cover shingle life in much detail, but it does compare traditional vented, unvented, and cathedral vented roofing systems. They all have their strong points but the cathedral vented is the recommended. http://www.fsec.ucf.edu/en/publicati...CR-1496-05.pdf |
All of the science and data that is being collected today is in complete contradiction to your assertions. The idea of ventilated assemblies in Fl and other hot and humid climates was based on very antiquated recommendations and using the shingle manufacturers of build code inspectors as you source of information is flawed at its source. 95% of the shingle cooling happens to the exterior surface via convection. I have never seen a report, although cited, showing a 32-40° difference between and unvented and vented assembly. As a matter of fact, orientation, color, and material have everything to do with surface temperatures. That being said, Las Vegas shingle roofs that were either well ventilated (1:150) vs. completely sealed only show a 9° difference in surface temperature (well withing guidelines and allowable maximums). Lets be clear about one thing, attic ventilation is for moisture. It always has been and will continue to do so. Removing moisture to prevent rot, mildew and mold is all it is intended for. Beside the energy efficiency reductions in a vented assembly (i.e. wind stripping of R-value, more building leakage, ice damns in low slope assemblies), vented assemblies can also entry pathway points for rain and bulk moisture and embers from brush fires. Don't get me wrong, if you are going to run a sealed attic/hot roof the details need to be correct. The vapor diffusion concerns are more pressing in colder climates. http://www.thermalsealexperts.com/air03.php http://www.buildingscience.com/docum...researchreport If surface temperature really ruined asphalt...wouldn't the roads be crumbling much faster? |
I have to agree with Windows (wish you would put in a real name) on this.
After doing some research on this whole issue I have come to the conclusion that for most applications an un-vented assembly is usually the best assembly. Especially here in dry fire prone conditions in So. Cal. Andy. |
A couple examples of how improper ventilation will void warranties (with exception to CertainTeed) http://www.iko.com/warranties/ 12. Any damage or distortion caused by inadequate ventilation either at the eaves or on the rooftop of the building. This includes failure of ventilation caused by blocked, non operative or defective vents or any other condition that renders the ventilation system ineffective. Roof system ventilation should meet local building code standards for total vent area. Ventilation must also be distributed evenly between the rooftop and the eaves of the building; http://www.bpcan.com/documentation-and-tutorials.aspx (b) the roof and each part of it must be designed and built in accordance with the applicable local and National Building Codes. All roof structures must be provided with thorough ventilation and the deck over which the shingles are installed must meet minimum building code requirements. Where local building codes have specific requirements which differ from National Building Codes, the more stringent requirement must be followed. http://www.certainteed.com/resource/roofing/warranties Fiberglass shingles can be non ventilated, and asphalt will only have a 10 year warranty. http://www.powerhrg.com/_files/files/Roof_Warranty.pdf GAF-ELK Goes into less detail than the rest, but says warranty does not apply if there is "inadequate attic ventilation" I do agree that shingle colour, orientation, etc have a lot to do with temperature, but I'm not sure what the maximum guidelines are that you refer to. Quote:
Page 10: Accordingly, if the average shingle temperature was elevated by 2°F, the shingle life expectancy might be reduced by 11% Mind you, average temp differences were noted at 1.3°. Just using a simple linear relationship would indicate that at 1.3°, the reduction in shingle life might be 7%. Page 9: One published reason indicates that attic ventilation keeps shingles from reaching excessively high temperatures and reduces the rate at which oxidation and hydrocarbon volatiles are driven off that make aged shingles become brittle (Terenzio, 1997). The role of temperature versus UV exposure is not well known, although temperature is commonly cited as having a critical role in shingle longevity (Cash and Lyon, 2002). However, experiments shows that ventilation is a lesser factor in resulting shingle temperature than is shingle color or geographic location. Rose (2001) showed that ventilation of a black shingle covered, truss framed roof only reduced temperatures by 2-3% whereas the impact of color was 20 - 30%. FSEC testing at its Flexible Roof Facility (Parker and Sherwin, 1998a) also shows that roof color and reflectivity is a very large effect– and larger than ventilation. So if color is the larger impact on shingle life, it begs the question again why any roofing manufacturer would sell a dark shingle if they are concerned about shingle life and surface temperatures. You can do any roof system improperly. I have seen spray foam done wrong just as I have seen vented roof done wrong. My big issue with a vented cathedral ceiling is the sacrificial R-value that is donated to a venting zone. If I were build a home today I would insulate with rigid foam to the top, vented overdeck, and use more traditional insulation materials to the interior with an airtight ceiling. |
| All times are GMT -4. The time now is 02:16 AM. |
