Garage Ceiling Installation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-21-2013, 09:36 AM   #1
Garage ceiling installation
Hi, I need some advice. I have a regular 1 car size garage. Walls and ceiling is covered with drywall and right above is a living room. In the winters the garage gets quite cold making the living room floor cold as well. Can I add anything to the ceiling to prevrent the cold getting through. Any changes to the living room floor is not an option as this was recently renovated with hard wood floors. Any advise is greatly appriciated.
Mario
Mario_R is offline   Reply With Quote
Old 10-21-2013, 09:46 AM   #2
Rewards Points: 12,878
If you were to "go over it" anything you would use would have to be fireproof.
Removing the sheetrock in the ceiling in the garage and building the joist down then adding more insulation and making sure the outside areas and any light fixtures where air sealed is the way to go in my option.
Old 10-21-2013, 11:49 AM   #3
Thanks Joe for the advise
Old 10-21-2013, 03:40 PM   #4
Rewards Points: 5,974
This might be a good area for a closed cell foam in the ceiling.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gary in WA (10-22-2013)
Old 10-21-2013, 03:55 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Mario_R View Post
I have a regular 1 car size garage. Walls and ceiling is covered with drywall and right above is a room. In the winters the garage gets quite cold making the living room floor cold as well.
How old is the house?
More recent construction should have some insulation between the spaces.
Investigate yours (poke a hole and look if needed).
If the joists are not insulated... blow something into the space.
Similarly... the space above that finished room.
Even if they are insulated... most of what you need will be supplemental heat (like a space heater) in the finished space above.
Old 10-22-2013, 01:18 AM   #6
Registered User
Rewards Points: 4,924
Fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Garage Ceiling Lighting Weekend_Warrior Electrical 13 05-21-2012 10:16 AM
Create Garage Ceiling For Insulating traeki Building & Construction 4 10-01-2011 11:11 AM
Insulate basement garage ceiling under living area? beckydewit Building & Construction 10 11-14-2010 12:59 PM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 03:46 PM
