Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-02-2011, 07:09 PM   #1
In a little over my head
gain from insulating walls
Building my addition to code has gotten me thinking about the rest of the house. The house is a one story ranch, built in 1958. We had cellulose blown in the attic a few years ago. The exterior walls are 1x10 lap siding, 3/4" celotex blackboard and 3/8" drywall. Nothing in the stud cavities. No fireblocking that I've seen. Checking with an infa-red thrmometer the last few mornings (32 degrees outside), the exterior walls are about 4 degrees F cooler than the interior walls.
How much improvement do you think we'd see, blowing cellulose in the walls? I'm in Atlanta; 95 degree summers, 30 degree winters.
Of course, I gotta finish this bathroom first.
ratherbefishing is offline   Reply With Quote
Old 12-02-2011, 08:15 PM   #2
Disabled wood vet
titanoman's Avatar
The difference would be like night and day.
titanoman is offline   Reply With Quote
Old 12-02-2011, 08:50 PM   #3
I hate to see insulation blown into walls for the simple reason there working blind. You shoot it in and hope the wall cavity gets filled, but what often happens is the insulation comes up againt some blocking, a wire crossing the bay ect. and it just dams up. it also always settles at the top of the walls and under the windows.
But unless you open up the walls inside or outside there not much choice.
I'd quess you would save at least 25% on heating and cooling cost.
A house that old will have had old style single paned windows, replacement windows would save you as much if not more. And any DIY can install them.
Old 12-02-2011, 09:45 PM   #4
Moderator
I'd contact your local energy department for an energy check. They have the instruments to evaluate how much and where you would save the most. Dense-pack cellulose would work effectively with your empty cavities (Celotex board is the shear sheathing- no wood diagonal blocking). Are there any storm windows? http://www.explainthatstuff.com/heatinsulation.html
http://bct.nrc.umass.edu/index.php/p...-smart-choice/
http://www.inspectapedia.com/structu..._Sheathing.htm
Gary
Clothes taking longer to dry?
Old 12-02-2011, 10:35 PM   #5
Thanks, guys. Windows have been done. We replaced single pane, metal framed, casements with vinyl Champions. I had them remove the metal frames and fit the windows to the RO's. I figure I'll start putting batting on the floor after this bathroom project is over.
Doing the walls looks like a big job. It involves drywall and painting. I'm not good with drywall. Luckily, my wife paints.
Insulating Superior Walls stradt03 Insulation 9 05-11-2011 07:09 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 10:50 AM
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 01:04 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating Existing Walls DarkWolf Building & Construction 2 03-06-2009 11:01 AM
