Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-22-2011, 06:13 PM   #1
Furring strips on top of XPS?
I'm considering a couple ways of insulating & finishing our basement walls:
-1- Glue 4x8 sheets of 1-1/2" XPS foam board to the concrete block walls. Seal seams with tape. Attach furring strips to XPS with tapcon screws through the furring strip and XPS into the concrete block wall. Attach drywall to the furring strips, which would leave a 3/4" or so space between the XPS and the drywall. Any thoughts?
-2- Attach z-channel metal furring strips to the concrete block wall, 24"o.c. The z-channel furring strips' design holds XPS foam board in place with little or no wall area uninsulated. They also have a surface to attach the dry wall to. Have any of you used these? What kind of price? Do they work as advertised?
Thanks,
Randall
randall.miller is offline   Reply With Quote
Old 08-23-2011, 11:21 AM   #2
Architectural Designer
AGWhitehouse's Avatar
Both methods work, though the z-channel has more thermal break point than the the furring strips, but it is negligable. Z-channels are the easier install of the two scenarios. With Z's you're shooting direct to concrete instead of 2-3/4" of material before you even hit concrete.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-23-2011, 11:15 PM   #3
Thanks for the reply. I'm having a bit of difficulty finding them. Do you have any idea how much they cost?
Old 08-24-2011, 07:14 AM   #4
Don't know the $, but a "real" building supply will have them. The box stores won't...
Old 08-27-2011, 03:22 PM   #5
Moderator
The furring strips (3/4") would be better if you added insulation at the air-space. Air seal the drywall (ADA- http://www.buildingscience.com/docum...wall-approach/), seal the rim joists with foam board and canned foam.
http://www.buildingscience.com/docum...m-at-rim-joist
The moisture condensing on the metal at the concrete wall would/could be a problem leading to rusting out due the foam storing moisture for extended periods and also contribute slightly to thermal heat sinks all over the wall.
Gary
Clothes taking longer to dry?
Old 08-27-2011, 05:20 PM   #6
GBR, the second link doesn't work...
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Gary in WA (08-27-2011)
Old 08-27-2011, 08:39 PM   #7
Moderator
Thanks, they are always changing the site! Here is the first choice, the one I thought I had, LOL.
http://www.buildingscience.com/docum...-at-rim-joist/
Gary
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
(Basement) Furring strips vs Traditional framing? ctote Carpentry 15 07-21-2011 01:00 PM
Furring Strips - Do I need them? ctote Remodeling 7 07-16-2011 09:09 PM
What size screws for furring strips on rafters TomFl Building & Construction 1 03-15-2010 08:59 PM
Best furring strips? J187 Building & Construction 5 06-03-2006 10:41 AM
