Furnace Room Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-25-2014, 07:43 AM   #1
Rewards Points: 326
Is it okay to put rigid foam insulation in the furnace room? Right now the exterior concrete walls are wrapped with a FG blanket and vapour barrier
The room will eventually be closed off with wood frames and firecode drywall.
Amitabh is offline   Reply With Quote
Old 03-25-2014, 09:05 AM   #2
Rewards Points: 13,750
I'd be using http://www.bing.com/search?q=roxul+i...sp=1&qs=OS&sk=
Instead.
Foam off gasses toxic fumes when heated and can not be left exposed.
Old 03-25-2014, 09:14 AM   #3
Rewards Points: 326
im using XPS from Owens Corning for the rest of the basement, but i guess the roxul is a good idea for inside the furnace room. but i dont want the vapour barrier and moisture trapping
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 06:50 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 05:44 AM
Furnace room is warm, wasting heat Richo HVAC 13 02-18-2009 12:57 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
