Framing Basements - Insulation - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 01:14 PM   #1
framing basements
1,000 sq.ft. with a 9 foot ceiling and cement walls for a basebent. How much material will I need?
TJshearin is offline   Reply With Quote
Old 01-08-2013, 04:08 PM   #2
Rewards Points: 13,984
Ok what's a basbent?
Got a tape measure?
Lengths of walls?
Old 01-08-2013, 11:15 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
2x4, 2x6, rigid foam on the wall, location, etc.
Bunch of question prior to getting an answer.
Old 01-11-2013, 01:44 PM   #4
Wow..sometimes it amazes me that when other folks are doing the same thing at the same time. Anyway, I have been pricing out what it will cost to insulate and frame my basement (which is also about 1000 sq ft.). I just used prices that I found online for supplies from Lowes using the following:
2" XPS foam + adhesive
2x4 studs (treated for bottom)
as well as roll insulation between studs (R10)
I have a spreadsheet at home that I will double check, but I believe that it was somewhere around $1900. I'll check when i get home and get back to you. I also priced it out using 1" XPS to be about $1300.
FYI, my basement consists of 2 standard size doors, 1 double door, and 2 (~5ft wide) windows...which obviously decreases the square footage of the walls.
markley is offline   Reply With Quote
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 03:17 PM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 09:12 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
