-   Insulation (http://www.diychatroom.com/f103/)
-   -   framing basements (http://www.diychatroom.com/f103/framing-basements-168592/)
TJshearin 01-08-2013 01:14 PM
framing basements
1,000 sq.ft. with a 9 foot ceiling and cement walls for a basebent. How much material will I need?
joecaption 01-08-2013 04:08 PM
Ok what's a basbent?
Got a tape measure?
Lengths of walls?
Windows on Wash 01-08-2013 11:15 PM
2x4, 2x6, rigid foam on the wall, location, etc.
Bunch of question prior to getting an answer.
markley 01-11-2013 01:44 PM
Wow..sometimes it amazes me that when other folks are doing the same thing at the same time. Anyway, I have been pricing out what it will cost to insulate and frame my basement (which is also about 1000 sq ft.). I just used prices that I found online for supplies from Lowes using the following:
2" XPS foam + adhesive
2x4 studs (treated for bottom)
as well as roll insulation between studs (R10)
I have a spreadsheet at home that I will double check, but I believe that it was somewhere around $1900. I'll check when i get home and get back to you. I also priced it out using 1" XPS to be about $1300.
FYI, my basement consists of 2 standard size doors, 1 double door, and 2 (~5ft wide) windows...which obviously decreases the square footage of the walls.
