Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-08-2013, 01:55 AM   #1
Frame basement sidewalls with 2x6 for thicker insulation?
We are getting ready to finish our basement and the majority of the basement is not currently framed. I am starting to wonder if I should possibly frame the perimeter walls with 2x6 boards instead of 2x4 to allow thicker insulation around the perimeter. If anywhere I am thinking to at least do the wall that is shared with the drive in garage which is attached, / walk out from basement, and pretty much open air. The remainder of the basement only has the top foot - two feet above grade.
troyce1 is offline   Reply With Quote
Old 01-08-2013, 02:21 AM   #2
More info will help. What is holding the walls up now? Are they just dirt? Heights? Where are you?
Old 01-08-2013, 07:09 AM   #3
Add a picture of the room, and go back and add your location to your profile.
More basement insulation Bonzoso Insulation 4 11-22-2012 10:18 PM
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Unfinished/Unheated Basement Ceiling Insulation mcusumano Insulation 4 08-31-2011 06:17 PM
Basement wall insulation dandw12786 Building & Construction 4 07-15-2010 02:11 PM
