Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-10-2011, 01:55 PM   #1
Foil faced rigid insulation question
I'm converting attic space to a living area. Because the roof rafters are 2x6, I'm considering using ridig XPS or ISO to increase the R value.Aside from cost issues, are there any advantages or disadvantages to using these products? Also, foil face boards offer a higher R value. Lastly, if I use the foil faced, do I still need a vapor retarder? Thanks in advance
123ozzie is offline   Reply With Quote
Old 12-10-2011, 06:22 PM   #2
Exterior Construction
Windows on Wash's Avatar
Where is the home located?
The benefit to the boards is a much higher R-Value per inch and their lack of sensitivity to wind currents.
Post up a picture of the attic and you will get more direct feedback.
Old 12-11-2011, 12:24 PM   #3
I'm located in zone 5. I'm confused mostly on wether or not to use the foil faced foam board. Does the asphalt paper between the shingles and the roof sheathing come into play? I know there isn't supposed to be a vapor retarder on both sides of the insulation. Also, can I double up two sheets of foil faced or not. Having trouble downloading pics. The computer and I sometimes don't see eye to eye.
Old 12-11-2011, 02:18 PM   #4
Your finished drywall will be your vapor retarded in this case.
http://www.buildingscience.com/documents/published-articles/pa-crash-course-in-roof-venting/view
At 2x6, you are only going to get R-35 at max into that assembly and that does not count on the R-Value drop as a result of the thermal bridging.
Vapor retarder is going to go the warm side (i.e. inside space) in this application. You are going to need to furr out the structure in order to get really good insulation depth and proper R-Value out of that roof.
insulation - faced or unfaced and which direction neil buckner Insulation 0 05-23-2011 11:22 AM
yet one more insulation question Mike in Arkansas General Discussion 6 11-11-2010 10:47 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
Sheetrock And Insulation Question kn1564 Remodeling 4 04-23-2010 12:24 PM
