Is This Foamboard A Vapor Barrier? - Insulation - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 10:21 PM   #1
Rewards Points: 152
Is this foamboard a vapor barrier?
I have this foamboard on my concrete walls in my crawlspace. Just wondering if it's considered a vapor barrier (like the pink or blue polystyrene) or if I should extend the plastic up to the sillplate?
Thanks!
burnt03 is offline   Reply With Quote
Old 06-03-2012, 10:52 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
EPS is the most vapor open of the foam but you don't need to run the plastic up to the sill plate.
Run the poly about 12" up the wall and you should be fine.
Old 06-03-2012, 10:54 PM   #3
Rewards Points: 152
Great, thanks!
One more related question.... in the crawl space, one of the concrete walls has the garage slab on the other side. It doesn't have the foam board on it. Does it need it?
Old 06-04-2012, 12:51 AM   #4
Originally Posted by burnt03 View Post
Great, thanks!
Ideally, yes.
Garage floors, although they may not be exposed via an outside wall, do conduct a bunch of energy and concrete, by itself, is not a good insulator.
If you are going to be down there, do it right and do it once.
Old 06-05-2012, 02:10 PM   #5
Rewards Points: 152
On a related note, I ended up putting a white foamboard on this concrete wall in our storage room (wanted to go with the pink XPS but they didn't have any). Planned on sealing it up then building a 2x4 wall in front of it.
The local building inspector mentioned that it has to have less than 60 ng/(Pa.s.m2) for it to work as a vapor barrier, and this stuff has 200 ng/(Pa.s.m2).
So could I just tape the plastic to the foam and to the existing vapor barrier on the framed wall above? Would I have to join the plastic to the floor with sealant or is it ok just to the bottom part of the foamboard?
Hope that question's clear, any suggestions?
Thanks!
Old 06-06-2012, 06:46 AM   #6
Poly over top would work as a vapor barrier at that point.
Just seal all the seams and lap them properly.
Flooring, foamboard, finish floor question(s). edselsouth1 Flooring 7 04-26-2012 12:34 AM
Any reason not to put on an inch of foamboard insulation under new siding? strategery Insulation 17 12-17-2011 09:34 AM
using foamboard....moisture barrier needed? bigbrad123 Building & Construction 5 10-25-2010 11:13 PM
Can foamboard insulation be used in living areas, vaulted ceiling? Spud Building & Construction 14 10-13-2009 12:48 AM
Sheathing with foamboard under siding billybarty Building & Construction 6 04-18-2008 12:46 PM
