Foam Insulation On Sloped Roof? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 07:19 AM   #1
Rewards Points: 640
Foam insulation on sloped roof?
Every energy audit site now says when you reroof you should add foam insulation to the roof to help keep your attic cooler. I even had a home auditor come out and tell me the same thing, but no one will tell me what this means exactly.
I even tried to look it up, and found no information, just people doing sprayfoam on the inside of the roof.
Does this mean ripping up the shingles, laying 2" of XPS foam then reshingleing? that would be too soft wouldn't it? or does it mean put foam on the roof deck, then deck over the foam, then reshingle? or is it talking about on the inside of the attic space?
if its on the inside, how would you do that with a finished cathedral ceiling?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 07-19-2012, 07:28 AM   #2
Rewards Points: 13,472
Google SIP roofing panels.
It's foam that been glued to the CDX or OSB.
Old 07-19-2012, 07:55 AM   #3
Rewards Points: 640
SIP's don't help though when you already have a roof deck in place, I don't want to replace the entire roof deck structure
Old 07-20-2012, 02:42 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
If the roof a hot roof with an insulated deck?
If it is a vented attic, you don't do anything of the sort.
Old 07-20-2012, 02:49 PM   #5
Rewards Points: 640
our "vented" attic is 150 degrees.... it's your standard soffit vent with vent baffels to keep the insulation from plugging it up type the soffit vents
problem is that 150 degree attic is making the second floor very hot, even with adequate air flow to the 2nd floor from the Central AC (CFM was verified as what the room should need at the registers)
that's where the auditor that came out said to insulate the roof to "fix" the issue....
the attic is already at R-40 with blown fiberglass...
one energy auditor wanted to remove the fiberglass and replace it with blown celulose to reduce air flow and heat transfer since it has a higher R value...
the part of the attic over the 2nd story part is only 4 ft high at the highest point I think it was, so the roof is pretty close to the room's ceiling level, even fully vented, one vent per joist cavity on the roof with the baffels and such, doesn't seme to help much.
I am putting in solar fan's to see if that helps, haven't goten to it yet though...
the odd thing is we have a 1 story master suite that doesn't get as hot as the 2nd floor... but it has a full attic witch is almost 13ft high at the peak but it doesn't get anywhere near as hot as the 2nd story attic space.. the hottest it was, was 110 degrees at the same time the 2nd story space was 150 degrees... and heat doesn't transfer in that space to the master suite like the 2nd floor one does... same type of blown in insulation also
Old 07-20-2012, 03:03 PM   #6
If the temperature is that far off from ambient, it is not vented proper or something else is exacerbating the heat issue. A properly vented attic should only be about 20-25 degrees off of ambient in a sloped roof (4:12 or better)
Your auditor might be a idiot in this case because that is about the most round about way to reduce heat in the attic.
Worst stuff on the market. Usually only works at about 50% of its theoretic value so your R-40 is really working like R-20 when it is warm.
Theoretically that is great but obviously the auditor is not paying for the work. Pulling out a bunch of fiberglass to throw it in the dump to put in cellulose is not smart. Over blow the fiberglass with cellulose and you will mitigate most of the convective down grading of the blown in fiberglass and make it work much better.
No sense in throwing it in the dump unless you have money to burn.
You need to air seal, baffle properly, and insulate. Put an R-50 combination of cellulose up there and the home will be worlds more comfortable.
I would say don't bother but if you have them, they can't hurt of the attic floor is properly sealed and air tight.
Lower sloped roofs will not cool as effectively in most cases. Check the venting again and make sure it is as open as you think.
Air seal
Check the vent chutes
Make sure the soffits are as open as you think as are the ridge vents
Insulate up to R-50 with cellulose
Tear up the card of your two auditors
Old 07-20-2012, 03:09 PM   #7
Rewards Points: 640
Air seal
yeah good point about the soffits, It's just standard vinyal perforated soffit... runs the full length of the eve overhangs, need to pull a few pieces and make sure there isn't fiberglass blocking the baffels or something stupid
when you say air seal, what are you meaning exactly? I had one guy come out and spray foam all the top plates (the big gun 2 part tank type, not the little DIY can stuff) until a couple inches over the drywall to stop air from traveling down the walls, not sure what much else is left to seal.
Old 07-20-2012, 05:31 PM   #8
That was pretty much it (i.e. air sealing).
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 09:25 AM
Attic roof insulation - how to? Fullenkamp General DIY Discussions 5 01-19-2011 07:21 PM
Attic Insulation on Roof MrSafety Roofing/Siding 2 06-13-2010 10:48 AM
Add insulation to solid timber roof justinNC Building & Construction 2 11-01-2009 12:16 PM
Flat Roof Construction- insulation EricC Roofing/Siding 15 12-02-2007 08:49 PM
