Foam Foundation Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 07:34 PM   #1
foam foundation insulation
is ISO foam as good as the blue foam for insulating the outside of a concrete poured wall assuming good drainage below and a 6 mill plastic between the foam and the backfill?
an attila is offline   Reply With Quote
Old 09-17-2012, 08:26 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Most applications for foam with dirt/moisture contact are best suited for XPS as opposed to ISO.
XPS is moisture insensitive whereas ISO is not.
Insulation: foam or cellulose? wombosi Insulation 1 07-06-2011 09:20 PM
HVAC ducting and foam insulation seadrift HVAC 1 08-17-2009 01:11 PM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 07:07 AM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 01:41 AM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 01:45 PM
