Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-20-2011, 03:00 PM   #16
bubbler's Avatar
foam and foam board flammability
Originally Posted by AGWhitehouse View Post
foam burns FAST. You shouldn't mess around here, it could get you into a heap of trouble.
Absolutely agree here.
Anyone doubts this, go buy three items from a HW store:
A 2x4, a FG batt w/ paper, and a chunk of Foamular (or similar foam board).
Hold a match under each one and you'll see what a VAST difference there is in burn rate, and the smoke produced... foam is scary stuff in that regard.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 10-21-2011, 12:45 PM   #17
for me that begs the question- code says drywall alone is sufficient as barrier to foam. interesting
federer is offline   Reply With Quote
Old 10-22-2011, 12:33 AM   #18
Architectural Designer
AGWhitehouse's Avatar
That is plenty sufficient covering. The purpose of the ignition barrier is to delay the inevitable combustion of the product long enough to ensure that the building inhabitants can escape. Drywall is used extensively in fire rated wall assemblies and 2 layers of 5/8" type X is generally considered to give a 1-hour rating.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-22-2011, 02:18 AM   #19
oh ok cool. so that will give me enough time to grab some stuff before i leave!
Foam board and electrical boxes Master Brian Electrical 5 11-21-2010 08:03 PM
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 05:46 PM
Foam Board on exterior of above grade house Sheldon General Discussion 6 12-08-2009 05:05 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
